Reboot loop with MPU enabled
This is a continuation of an earlier thread...
@dc42 Now when I boot with the SBC connected, I get a boot loop. It happens somewhere in the middle of processing config.g with a "Controller has been reset" message.
The end of the M122 output may be a little wonky because it was also capturing the GCode output from config.gM122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12+1 running on Duet 3 MB6HC Board ID: 08DGM-9T66A-G63SJ-6J9F4-3SD6S-1U03B Used output buffers: 1 of 32 (5 max) === RTOS === Static ram: 122240 Dynamic ram: 167708 of which 0 recycled Exception stack ram used: 212 Never used ram: 103056 Tasks: NETWORK(ready,2068) HEAT(blocked,1456) CanReceiv(suspended,3804) CanSender(suspended,1480) CanClock(blocked,1464) TMC(suspended,256) MAIN(running,4492) IDLE(ready,200) Owned mutexes: === Platform === Last reset 00:00:00 ago, cause: software Last software reset at 2019-11-10 09:11, reason: Memory protection fault, spinning module GCodes, available RAM 101704 bytes (slot 1) Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x04432804 BFAR 0x00000086 SP 0x20415c9c Task 0x4e49414d Stack: 00452a63 0043baf0 81000000 00000000 0042a57b 20422404 20424f38 00000004 0046e568 20423d00 00000000 01000000 00000000 0042b091 00000000 00000000 00429c25 00000000 20422300 20423d00 0043ae01 00000000 20415e2a Error status: 0 Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 70.0, current 8.9, max -284.0 Supply voltage: min 0.9, current 1.0, max 1.0, under voltage events: 0, over voltage events: 0, power good: no 12V rail voltage: min 0.3, current 0.3, max 0.4, under voltage events: 0 Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Date/time: 1970-01-01 00:00:00 Slowest loop: 2.16ms; fastest: 0.17ms === Move === Hiccups: 0, FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 1 allocated, 1 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is assembling a command in state(s) 0 daemon* is ready with "M122" in state(s) 0 0, running macro queue is idle in state(s) 0 lcd is idle in state(s) 0 spi is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.24ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - Ethernet - State: 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 0, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 13ms ago RX/TX seq numbers: 45063/5 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 20/180-0 === Duet Control Server === Duet Control Server v1.1.0.5 Daemon: => 596 bytes > Suspended code level Code buffer space: 3500 Configured SPI speed: 2000000 Hz Full transfers per second: 9.85
I'm sorry, I no longer have symbol files for that build. Please try the firmware now at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 and assuming the problem still occurs, post the M122 report again. Also please post your config.g file as I suspect that some command in it that is missing from my config.g may be triggering the reboot.
@dc42 It looks like that build fixed it.
