Help to configure order
please fix site authentication issue.
ID from forum does not work for shopping (" Warning: The E-Mail Address was not found in our records, please try again!")
i have created different ID for shopping
forgot new password and used "reset password" form
response: " An email with a confirmation link has been sent your email address." -
got link in the email and created new password
response: " Password succesfully updated " -
used my email (from newly created account) and new password to login - FAILED
response: " Warning: No match for E-Mail Address and/or Password."
in fact, i tried changing password 3 times. all attempts failed.
meanwhile some tech questions (was not able to find on the site)
are all fans output for 5 volt ?
there are two "always ON fans". are they also 5v? do they support PWM or other type of speed control?
accepting 0.9 deg motors means 24v power supply.
are there 12v outputs on the board (i need it for LED light)?
thank you!
1. There is a jumper that allows you to set the fan voltage supply to either 5V or VIN. The jumper affects the voltage supplied to all fan outputs.
2. The always-on fan outputs do not support PWM.
3. There is no 12V output on the Duet. There is on the DueX expansion boards.
thanks for answers.
please help me to fix login issue for shopping.
Hi i have emailed you back.
placed an order. thank you from fantastic support!
