IR sensor
Evening all just wanted to clarify that mode P2 is correct for the Aus3d IR height sensor please.
M558 P2 H15 F100 T6000 R0.5 A5 B1
I've got an Aus3d IR. I can check my config after work tonight and let you know.
M558 P1 H3 F300 T6000 A5 S0.015
I used P1 and the analog output of the IR sensor.
If you use the analog output Duet will slow the dive speed down as the probe nears the trigger height. I found this gave more repeatable results.
@insertnamehere
Many thanks for the info much appreciated!
Would I be correct in assuming the R value in my line of code is a repeat measurement feature until two consecutive measurements are of the same value it will keep repeating.
This is the line of code I was using with my BLT but with P9 and it still worked after I fitted the Aus3d. I was just worried that I may create other issues by not altering it.
P1 is correct for the IR sensor on Duet 2 and legacy Duets.
The R parameter is a settling time, not needed for the IR sensor. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type.
@insertnamehere said in IR sensor:
So taking into account I used to have a BLtouch and now I have the Aus3D ir sensor which homes fine thank you using the command line given earlier is there something else I have to reverse as I now have an error message following the homing.
Error M280; invalid servo index 7 in M280 command.(repeat text)
remove the retract/deployprobe.g files from sys.
also check for M401/M402 command in your homing files or M98 calling the macros.
@Veti Hey thank you it was the deploy and retract files remaining error message gone!
Much appreciated help as always
