Warning: VIN over-voltage event (29.7V)
This warning message is keep on coming every sec, what could be the issue?
otherwise all works fine
Due to this the main page of DWC act differently ("Processing " indication at the left corner changing every sec. to "off" and conmes back
which duet?
Duetwifi 2
Either the VIN voltage from your PSU is too high, or something is overloading the 3.3V rail, causing the voltage to be less than 3.3V. The 3.3V rail is used as the voltage reference when measuring VIN.
Ok , I've taken 3v from external source, that could be the reason, coz my Duet 3.3V rail conked off
This post is deleted!
