    Eclipse
    Firmware developers
    1.4k
    • fcwiltundefined
      fcwilt
      Perhaps you are working with a different Eclipse?
      Which IDE are you trying to install? I cannot try it at my end until I know.
      • PrintMakeundefined
        PrintMake
        Steps 1,2,3 are easy step 4 is setup path in windows OS “environmental variable”
        Looking forward towards step 5 .
        dc42 Step 5 in buildinstructions. what is all about?
        mloidlundefined 1 Reply Last reply Reply Quote 0
        • mloidlundefined
          mloidl @PrintMake
          @ViralTinker
          Step 5 is to check if the commands rm and make are correctly found in the PATH, after adding the bin Folder from Step 4 into it.
          which is definitely a UNIX/LInux command and won't work on Windows.
          You can try to replace which with whereon Windows. This should work, but i cannot test it.
            PrintMake
            I feel much lighter know , 😄
            How build instructions can be updated is it via pull requests??
            So Step 5 almost can be skipped!?
            • mloidlundefined
              mloidl
              IMO this step is optional. It's just to verify the commands rm and make are available within the build process.
              The build instructions can be changed by uploading a pull request, since it's just a file in the RepRapFirmware-Repository.
              If you can verify where is working on Windows i can do that for you, or you ask @dc42 if he will do it within the next commit.
              PrintMakeundefined 1 Reply Last reply Reply Quote 0
                PrintMake @mloidl
                @mloidl
                Just to double check , are you saying ‘where’ Command just need past in Command line?
                • mloidlundefined
                  mloidl @PrintMake
                  @ViralTinker
                  You have to type where rm in the command line after you modified your PATH.
                  To ensure the PATH is correct you can show it by typing echo %PATH% in the command line.
                  Maybe you have to restart the command line if you modified the PATH somewhere in your Windows Settings.
                  If you only type where in the command line you'll get a description how the command works (including some examples)
                    PrintMake
                    Ok thanks
                      PrintMake
                      Hi again everyone,..
                      Now step 7 is easy
                      1. Download this github project as a zip file and unzip it into C:/Eclipse/Firmware. Then rename folder ReprapFirmware-dev in that folder to RepRapFirmware.
                      After this it gets interesting
                      Is that mean you can use RepRapFirmware itself without CoreNG and DuetWiFiSocketServer and RTOS-enabled ???
                      • oliofundefined
                        oliof
                        No, you need to complete the following steps as well.
                          PrintMake
                          Can we continue ?, Shall we?!
                          What function CoreNG does?
                            CoreNG abstracts most of the hardware. Many years ago it started out as the Arduino Due core, but it's been almost completely rewritten over the years.
                              PrintMake
                              Is that where the name“Duet” comes from ?
                                PrintMake
                                How about DuetWiFiSocketServer and RTOS-enabled ???
                                If I understand correctly DuetWiFiSocketServer,handles protocol to send packets???
                                And RTOS real time operations?
                                  DuetWiFiSocketServer is the source code for DuetWiFiServer.bin. You don't need to build it if you just want to change RRF, but you do need it in the workspace because RRF uses one include file from it.
                                  All RRF2 builds use RTOS except the builds for Duet 06/085, RADDS and Alligator. All RRF3 builds use RTOS.
                                    PrintMake
                                    Managed to Compile existing files without editing .
                                    I wish buildinstructions could be more detailed.
                                    AFTER SUCCESSFUL COMPILING WHERE IS .BIN FILE?
                                      dc42 administrators @PrintMake
                                      @ViralTinker said in Eclipse:
                                      In the project directory there is a binary directory for each configuration.
                                        PrintMake
                                        Found it Thank you
