    Bed leveling weird all of a sudden
    • 3dprinting meatheadundefined
      3dprinting meathead
      I've had my printer going for a while now, but just upgraded to direct drive. I had to change my z offset with the new mount, and when I try to g29(with a fully functional Bltouch), it will probe for home then goes all the way to the other side of the print bed. It never did this before, is this normal?
      Here's my g29 macro:
      G28
      G91
      G1 Z4 F300
      G90
      M98 Pdeployprobe.g
      M557 X1:220 Y0:160 S20
      G29
      M98 Pretractprobe.g
      G1 X25 Y0 Z20 F5000
      does this look wrong? I'm at a loss here.
      If I can learn it, than anyone can learn it.
        Are there any error messages on the console? G29 probing will be abandoned if a probing move fails.
          3dprinting meathead
          Well, no error messages or codes, it just kinda decided to run bed leveling starting from away from the endstop and moving toward it. After it scaring me twice, I reset the x probe area to 200 and let it run and it works fine.
          My map comes up with the axis indicator(those xyz lines that form a partial box) on the right now instead of the left, kinda confusing at first but it works so I must adapt.
          And I did get a perfect first layer so it's definitely functioning right.
          I'll mark this as answered because it does work.
