    [feature request] Air pressure advance
    Firmware wishlist
    673
    • gouryundefined
      goury
      So we have this feature that compensates springiness of filament, called "pressure advance".
      How's about we do something like this for cooling?
      The problem: fans take time to spin up and air pressure takes time to advance.
      The solution: look ahead for fan powering up command and power it up early.
      I believe it's better to be done in firmware than hacked into GCODE, because it is machine-specific.
      My case: I found that my fans take about 1.8 seconds to spin up, resulting in PLA bridges sagging in the beginning if I do nothing to my GCODE.
      Yes, it's almost a second before it spins up from 40% to 80% and then some more before it reaches full power.
      It is very much noticeable.
      • burtoogleundefined
        burtoogle
        Perhaps it is better to implement fan look ahead in the firmware, I don't know. In the meantime, if you use Cura, install one of my builds and there is a setting (Cooling Fan Lag) that controls fan look ahead for feature specific fan speed changes (bridging, skin over support, etc.). You can find my builds at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0 and they can be installed alongside the UM releases. Please read the README.md at the above location if you wish to give it a go.
        • botundefined
          bot
          I think this could be useful, in some situations.
          Another useful lookahead feature that goes hand in hand with this would be temperature change. If a tool has a temperature change (say, from standby to print temp) coming up, the printer could use the model of the heater to pre-heat the tool so that it reaches its temp at approximately the exact moment the tool is needed.
          *not actually a robot
          burtoogleundefined 1 Reply Last reply Reply Quote 1
          • denkeundefined
            denke
            I agree, this would be useful!
              burtoogle @bot
              @bot said in [feature request] Air pressure advance:
              Cura has done exactly that for some years now. Don't all slicer's do that anyway?
              botundefined gouryundefined 2 Replies Last reply Reply Quote 0
              • botundefined
                bot @burtoogle
                @burtoogle I had no idea that Cura did this. I've been using S3D for years, for better or for worse. S3D does not plan ahead with the temperatures.
                • gouryundefined
                  goury @burtoogle
                  @burtoogle Cura also does lot things badly, like nonexistent nozzle wipe or just forgetting/resetting some settings while lying about it in the interface.
                  It's just too buggy there's no way I can use it and not hate myself every moment I do.
                  You can't even change your nozzle width in default profile without duct tape in latest stable version.
                  And it is like this for a very long time (since 3.4 or 3.5 IIRC).
                  • Edgars Batnaundefined
                    Edgars Batna
                    It would be awesome if it was in the firmware. Already accustomed to having things like pressure advance, retraction, acceleration adjustment etc in the firmware and using some slicer for this would be like giving up air.
                    To be entirely honest, most slicers are useless in determining what's good for a machine. They're only good enough to make a path out of a model. The rest, as far as my experience with Duet goes, is better off sitting in the firmware as it's the only one with all the machine parameters.
                      One of our plans for Duet 3 is to have a "Read ahead" GCode stream that reads the printing GCode ahead of the main stream and simulates them, looking out for operations coming up that have an associated delay - such as changing the filament mix in a mixing extruder, and switching to a different tool that needs to be heated up. Then the firmware will be able to advance those operations.
                      • A Former User?
                        A Former User
                        @goury
                        And why not add another fan-Advance for the cooling fan of the heatbreak of the extruder:
                        That Needs to be spun up before retract, but could be considerably lower when feeding out material.
                        Two extreme examples:
                        • A complicated part with endless retracts that need to keep the heatbreak cool so with all the retracts the heat doesn´t slowly go/creep up the heatbreak-tube, with 100% pwm for that fan.
                        • An endless spiral Vase, that has 0 retract (oh wait, when the part is finished there is 1 retract at the end) which could run considerably quieter and consumes less electricity, e.g. with the same fan on a pwm of ca. 25-50% because the heat is pushed out way more with the filament.
                        Since fans take time to change speed, there would need to be some sort of look ahead, that compensates for ca. 1-2seconds lag of the fan.
                        Lucas
