    Unsolved Commissioning Duet 0.8.5 and Duex4 v0.2a Setup
    • JUNK
      JUNK last edited by JUNK
      Hi
      I am in the process of commissioning my Duet 0.8.5 and Duex4 v0.2a Setup.
      I bought them from Think3dPrint3d a number of years ago. This is my first time using them.
      I have successfully setup and tested the Duet 0.85 board on its own and had a successful print.
      The configuration was created using the "RRF Config Tool"
      I am now in the process of setting up the Duex4 v0.2a board.
      I have connected the ribbon cable and run a separate V+ from my power supply to the Duex4. I have connected a shorter wire from the Duet 0.8.5 -ve connector to the Duex4 -ve connector.
      I will be adding a Diamond Hot End to the Duex4
      The additional code that I have added to the config.g file is follows
      M569 P5 S1 ; physical drive 5 goes forwards Ex3 (Diamond)
      M569 P6 S1 ; physical drive 6 goes forwards Ex4 (Diamond)
      M569 P7 S1 ; physical drive 7 goes forwards Ex5 (Diamond)
      M305 P3 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 3 (Diamond)
      M143 H3 S280 ; set temperature limit for heater 3 to 280C
      M106 P3 S1 I0 F500 H3 T45 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P2 S"Diamond" D2:3:4 H3 F2 ; define tool 3
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      The Web interface shows the "Diamond" tool added and the additional extruder motors.
      There is a single red LED lit on the Duex4 at location D5.
      I have tried connecting my thermistor into the Duex4 and no measurement is recorded (2000.0C on the Web interface)
      I have tried it at all the possible locations for thermistors shown in the wiring diagram
      https://reprap.org/wiki/File:Duet_0.8.5_Duex4_wiring_0.2.svg
      (my board has the pin connectors rather than the screw connectors)
      I have tested the thermistor by connecting it to the Duet board and it gives a believable reading.
      The M115 command does not list the Duex4
      FIRMWARE_NAME: RepRapFirmware for Duet FIRMWARE_VERSION: 1.24 ELECTRONICS: Duet 0.85 FIRMWARE_DATE: 2019-06-13b2
      Should the Duex4 be listed here?
      Do I have a problem here? Have I miss-configured my system?
      I will post the M122 output in a reply post.
      I have an existing problem where the heater for T0 is continuously on. I am currently ignoring that as I don't intend to use it. However it is possible that it might be relevant here.
      Thanks in advance.
      Jamesconfig.g
      • JUNK
        JUNK last edited by
        M122
        RepRapFirmware for Duet version 1.24 running on Duet 0.85
        Used output buffers: 3 of 16 (16 max)
        === System ===
        Static ram: 44204
        Dynamic ram: 42812 of which 3096 recycled
        Stack ram used: 136 current, 3428 maximum
        Never used ram: 4764
        Last reset 01:39:41 ago, cause: power up
        Last software reset at 2019-11-13 21:33, reason: User, spinning module GCodes, available RAM 5004 bytes (slot 3)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff
        Error status: 4
        Free file entries: 10
        SD card 0 detected, interface speed: 10.5MBytes/sec
        MCU temperature: min 3.5, current 26.5, max 28.6
        Date/time: 2019-11-14 16:23:19
        Slowest loop: 60.74ms; fastest: 0.10ms
        Hiccups: 0, FreeDm: 100, MinFreeDm: 97, MaxWait: 2213185ms
        === DDARing ===
        Scheduled moves: 10, completed moves: 10, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
        Bed heaters = 0, chamberHeaters = -1 -1
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is assembling a command in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Free connections: 15 of 16
        Free transactions: 23 of 24
        Locked: 0, state: 4, listening: 20071bf4, 0, 0
        • JUNK
          JUNK last edited by
          @JUNK said in Commissioning Duet 0.8.5 and Duex4 v0.2a Setup:
          Error status: 4
          It looks like I have an error, Where I I find out what this means please?
            dc42 administrators @JUNK last edited by
            The thermistor series resistors on most DueX4 boards are 1K. So you probably need R1000 in the M305 P3 command, not R4700. Alternatively, connect the thermistor to the Duet.
            • JUNK
              JUNK last edited by
              DC42
              I have not been able to get a reading from the thermistor when connected to the duex4 with the change you suggested. It does work when connected to the duet. I have noticed that M115 does not list the duex4. Should it be showing it? Do I have a more fundamental problem?
              M115
              Thanks
              James
