Reprap configerator not recognising .json file
Good evening all
I would like to edit a few printer parameters in the Reprap config tool. I downloaded my config files, when I try and re upload the .json file to the config tool I get the following error message:
I have attempted this in Chrome and EE on two computers... same error message. Any help is appreciated!
Cheers
Tim
I just tested this and the json file uploaded correctly. Were you uploading the json file from within the zip file? Maybe check that it's decompressed first before uploading.
Hi Ian, thank you for checking this!
I had no luck in the end and made my changes in the config files manually.
Again thank you for checking this none the less,
Tim
Would you be able to provide the json file in question?
