    immediate driver-disable when not in use
    • tooundefined
      too
      Hello!
      Just for context - I am working with a large scale concrete printer. I am trying to find a better way of controlling a mixing pump, that pumps material into the printhead.
      I basically want to enable a relay every time the extruder starts and turn off the relay as soon as the extruder driver is not extruding anymore. I have access to the enable signal through a duex5 expansion board.
      I though I could use the enable signal that is present on the breakout board, however this enable signal does only switch polarity once - then stays the same.
      Has anyone an idea if there a way to generate a simple on / off signal that correlates with driver moving / not moving??
      Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
        dc42 administrators @too
        Does this help https://duet3d.dozuki.com/Wiki/Gcode#Section_M571_Set_output_on_extrude ?
        • tooundefined
          too
          Thanks, that does indeed look like it could help. I'll try that!
