    New duet wifi board; Z driver not working.
    • bluedust2undefined
      bluedust2
      I have just set up the board to test all the hardware is working and I can't get a motor running on the z driver. The z driver is also hot to touch while in idle. I have checked motors that work on the x,y,e0,e1 drivers and they don't work on the z driver.
      Is there anything else I can check?
      • Vetiundefined
        Veti
        are the jumpers installed on the second connector?
          bluedust2
          yes jumpers are on the zb connector.
            It sounds like a faulty driver, but please check the following:
            • Does the Z driver chip run hot even with no motor connected?
            • Have you checked that the Z motor connector pins on the underside of the Duet are not shorting against anything metallic underneath the Duet?
            • When you send M122, what status does it report for driver 2?
            bluedust2undefined 1 Reply Last reply Reply Quote 0
              bluedust2 @dc42
              @dc42 No shorting, I have it in an abs enclosure bottom half to keep it safe.
              The z driver chip was hot even when no motor was connected so I put a small heatsink on it, no improvement.
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-917DA-G4MS4-6JTD2-3SN6N-TTXH9
              Used output buffers: 3 of 20 (7 max)
              Static ram: 25524
              Dynamic ram: 98832 of which 0 recycled
              Exception stack ram used: 280
              Never used ram: 6436
              Tasks: NETWORK(ready,680) HEAT(blocked,832) MAIN(running,3844) IDLE(ready,200)
              Owned mutexes:
              Last reset 00:00:33 ago, cause: power up
              Last software reset at 2019-11-25 19:04, reason: User, spinning module GCodes, available RAM 6344 bytes (slot 2)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
              Error status: 0
              Free file entries: 10
              MCU temperature: min 24.4, current 28.3, max 28.4
              Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Date/time: 2019-11-25 23:31:05
              Cache data hit count 117292142
              Slowest loop: 5.81ms; fastest: 0.07ms
              I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
              Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
              Scheduled moves: 0, completed moves: 0
              Bed compensation in use: none
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 15.83ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is running
                WiFi firmware version 1.23
                WiFi MAC address 84:0d:8e:b2:f2:32
                WiFi Vcc 3.36, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25720
                WiFi IP address 192.168.178.86
                WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                I am sorry, if the Z driver gets hot with no motor connected to it, and nothing is shorting against the Z motor terminals, then the Z driver has failed. As your board is new and assuming it's a genuine Duet, you are entitled to a replacement under warranty, so please contact your supplier.
