    Determining if an axis is moving
    • ctundefined
      ct
      I am sending individual commands using the serial port. Is there a way to determine if an axis is moving or has reached its destination?
      • Danalundefined
        Danal
        Not really "determine", but an M400 after the original command will not execute any more commands until the planner queue is empty and moves have completed.
        This may accomplish what you want in a different way.
          You could use M408 to poll the status, waiting for the status to be idle. But sending M400 and waiting for the OK response may be simpler.
          • ctundefined
            ct
            Thank you for both replies. M400 will give me what I need though I can see a use for M408. Is there a recommend poll frequency?
              dc42 administrators @ct
              @ct said in Determining if an axis is moving:
              No more than 4 times/second.
              • ctundefined
                ct
                Thanks for the information.
