    5v Inductive endstop’s
    • TheLightSpeedundefined
      TheLightSpeed
      Hey! So I have 5v Endstops. I would like to keep 5v inductive Endstops. I know I can use Pin1 of the expansion header for a 5v source while keeping the ground and signal hooked to the regular pins. My question is obviously I have a X, Y and Z endstop and only 1 5v pin. Can I connect all three 5v pins to that one pin on the expansion header without damaging it? I’m assuming 3.3v won’t be enough to power them.
      Thanks.
      M911 ah crap... wipe, and start over.
      • Vetiundefined
        Veti
        only if you have a duet wifi 1.04
          dc42 administrators @Veti
          @Veti said in 5v Inductive endstop’s:
          Or a Duet Ethernet 1.04, or Duet Maestro, or Duet 3.
          TheLightSpeedundefined 1 Reply Last reply Reply Quote 0
            TheLightSpeed @dc42
            @dc42 I do David thank you!
