    Firmware Retract zhop/lift speed
    • adavidm
      adavidm last edited by
      Is there a default feedrate for the zhop/lift during a firmware retract? I'm wondering if that feedrate has a bearing on the size of the blob left behind following a retract and if it can be tuned at all? Smoothieware has a Q parameter to the M207 command that seems to allow this to be configured. I had a quick look in GCodes2.cpp, but M207 makes no mention of the Q parameter so I'm assuming it's not supported in RRF.
      The RetractFilament() function in GCodes.cpp has the following section:
      [[c++]]
      				// Set the feed rate. If there is any Z hop then we need to pass the Z speed, else we pass the extrusion speed.
      				const float speedToUse = (retract) ? retractSpeed : unRetractSpeed;
      				moveBuffer.feedRate = (retractHop == 0.0 || retractLength == 0.0)
      										? speedToUse
      										: speedToUse * retractHop/retractLength;
      				moveBuffer.coords[Z_AXIS] += (retract) ? retractHop : -retractHop;
      but I can't see where the Z speed is being passed as per the comment.
      It would be nice to have in the firmware as it would be another setting to play with during a print for fine tuning.
      Regards
      David
      • kraegar
        kraegar last edited by
        See DC42's answer here: https://www.duet3d.com/forum/thread.php?id=1156
        Co-Creator of the RailcoreII CoreXY printer
        https://www.thingiverse.com/thing:2407174
        • adavidm
          @kraegar:
          Completely missed that, thanks!
