    Bed and/or hot end over temp signal
    • ajlappundefined
      ajlapp
      Is there currently a usable DIO or other physical signal that is trigger by a hot end or bend over temp?
      I’m looking to add a secondary safety system to my printer that cuts main power if there is a thermal runaway.
      I’d like to use the signals coming from the Duet as part of the system if they’re accessible.
        dc42 administrators @ajlapp
        In RepRapFirmware 3 you can do that, by defining a GPIO pin as a thermostatically-controlled fan, set to turn on if a defined temperature is exceeded.
        However, IMO it would be safer to use an independent temperature sensor.
        ajlappundefined 1 Reply Last reply Reply Quote 0
        • ajlappundefined
          ajlapp
          Thanks for the quick reply.
          My thought was to bring in the Duet pin and a secondary pin and OR them into a master shutoff.
          • ajlappundefined
            ajlapp @dc42
            @dc42 <quote>defining a GPIO pin as a thermostatically-controlled fan</quote>
            Any insight into how to define this? It's not clear to me. Thanks.
            • ajlappundefined
              ajlapp @ajlapp
              @ajlapp Looks like M42 is the correct direction
