    "Define Area for Mesh Grid Compensation" -how to save?
    Duet Web Control
    689
    • jontek2undefined
      jontek2
      Hey,
      In the duet web control there is a function called "Define Area for Mesh Grid Compensation" and every time i update the values it goes back when i power off. Is there a way to save? Where is the data stored for this?
      I'm using a BLtouch on my duet2wifi i've configured the mesh grid compensation. For this i've added the following to my config.g:
      M557 X0:210 Y0:210 S20
      But everytime i start my printer it says X180 and Y180.
      So - how do i save it so it's X210 and Y210?
        dc42 administrators @jontek2
        @jontek2 said in "Define Area for Mesh Grid Compensation" -how to save?:
        What "says X180 and Y180"? Do you mean that if you send M557 without parameters, it reports X0:180 Y0:180 ?
        • jontek2undefined
          jontek2
          • jontek2undefined
            jontek2
            M557 gives me:
            Grid: X0.0:210.0, Y0.0:210.0, radius -1.0, X spacing 20.0, Y spacing 20.0, 121 points
            But it's only probing to 180x180. It only goes to 210x210 if i change it in the image above.
              I think the 180 you are seeing there is just a default value. If you already have the M557 command in your config.g set correctly you don't need to send it again in the DWC.
              • jontek2undefined
                jontek2
                No, i once put 180 in there.
                The problem is whatever i put in M557 doesnt overwrite the value in "Define Area for Mesh Grid Comp..".
                If i reboot my duet2wifi and run a G29 it does it by 180x180. If i then update the values it does it by 210x210 (or whatever i put it to).
                Where is this value saved?
                • Vetiundefined
                  Veti
                  in your config.g
                  see
                  https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
                  System Editor
                    It looks to me that it doesn't get saved (possibly it does if you are running on a Duet 3 with an attached single board computer, I haven't tested that). I'll raise this with the author of DWC. Ideally it should retrieve the current M557 values from the Duet and present those as the initial values.
                    Meanwhile, if you always use the same values, then just put those values in the M557 command in config.g and don't use the "Define area for mesh compensation" feature of DWC. You can send M557 from the console to check what the current M557 parameters are.
                    • jontek2undefined
                      jontek2
                      Thanks!
                      I just want to clarify that i have the following in my config.g:
                      But it doesnt mater because it doesnt take those values in affection. It goes to the 180x180 value that's somewhere stored in the "Dwfine Area for Mesh Grid Comp..".
                      • jontek2undefined
                        jontek2
                        Hey @dc42
                        Did you have any updates on the "Define Area for Mesh Grud Compensation"-save bug?
                        • chrishammundefined
                          chrishamm administrators
                          DWC 2.0.5 uses the values from its object model to set the values in the mesh edit dialog but those values aren't updated from RRF/DSF yet. That will be likely implemented in DWC 2.1.0.
                          Duet software engineer
                          • jontek2undefined
                            jontek2
                            This post is deleted!
