HBS57 external closed loop driver M569 config needed.
  • undefined
    wydowaw
    Post heading;
    Firmware Electronics: Duet Ethernet 1.02 or later
    Firmware Version: 2.04RC1 (2019-07-14b1)
    Web Interface Version: 1.22.6
    CoreXY, double Z steppers
    2x E3D Supervulcano 3.0- 1.0 nozzle
    2x Bondtech QR 3.0
    ALL External drivers, on expansion board
    Using DM860A external drives, which perform Perfect !! with the settings below. (double Z axis)
    However the new setup with HBS57 for xy is not moving at all.
    [https://www.ebay.nl/itm/254313299512?ul_noapp=true](link url)
    Anybody out there; who has a working M569 setup of this type of external drivers...??
    Thanks for your time and help.
    ;EXTERNAL drivers on expansion breakout board v1.1 Drive 8 and Drive 7
    ;Longs Motor 2H Microstep driver DM860A, SW1 upto SW7 ON= 2.8A Peak ,400 Pulse/rev
    ;Nema34 4 wire
    M569 P8 S1 R1 T2.5:2.5:5:0 ; driver 8 goes forwards, requires an active high enable, 2.5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup time and no hold time= E5 extensionboard =Zleft
    M569 P7 S1 R1 T2.5:2.5:5:0 ; driver 7 goes forwards, requires an active high enable, 2.5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup time and no hold time=E4 extensionboard =Zright
    ;EXTERNAL drivers on expansion breakout board v1.1 Drive 5 and Drive 6
    ;HBS57 Closed-Loop Driver + Nema23 23SSM6440-EC1000 , 4.0A Peak, 800 Pulse/rev, 42V DC
    ;Nema23 4 wire
    ;M569 P5 S1 R1 T2.5:2.5:5:0 ; driver 5 goes forwards, requires an active high enable, 2.5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup time and no hold time=E3 extensionboard =Xa
    ;M569 P6 S1 R1 T2.5:2.5:5:0 ; driver 6 goes forwards, requires an active high enable, 2.5us minimum step pulse, 2.5us minimum step interval, 5us DIR setup time and no hold time=E2 extensionboard =Yb
    Regards,
    Wydo van de Waerdt
    • undefined
      Have you tried R0 instead of R1 ? Some external drivers have enable inputs, others have disable inputs. You have the correct R parameter when the drives are free to move at power up, and lock when you first try to move them (whether they move or not).
      • undefined
        wydowaw
        @dc42 said in HBS57 external closed loop driver M569 config needed.:
        Thanks for your reply, it's very much appreciated.
        Yes I tried both also with increased numbers.
        ;HBS57 Closed-Loop Driver + Nema23 23SSM6440-EC1000 , 4.0A Peak, 400 Pulse/rev, 24V DC sw1-sw7 ON,SW1 on=down edge
        ;Nema23 4 wire, enable+ and enable- Not connected !!
        M569 P5 S1 R0 T6.0:6.0:6.0:6.0 ; driver 5 goes forwards, requires an active high enable, 6us min step pulse, 6us min step interval, 6us DIR setup time and 6us hold time=E3 extensionboard =Xa
        M569 P6 S0 R0 T6.0:6.0:6.0:6.0 ; driver 6 goes backwards, requires an active high enable, 6us min step pulse, 6us min step interval, 6us DIR setup time and 6us hold time=E2 extensionboard =Yb
        No-power= free movement
        Both setting R1 or R0 lock the steppers. (so that's possitive ;-))
        However homing X shows the following problem.
        I checked the wiring of the stepper coils A and B, according diagram and measured.
        The enable cables are both disconnected on the external drives.
        i tried :
        ena+ and ena- connected => red led on driver
        ena+ connected not functioning no warning (same phase error!!)
        ena- connected not functioning no warning (same phase error!!)
        any suggestions are welcome.... (my current clossed stepper setup is still a non-moving machine ;-((
        • undefined
          It sounds to me that you haven't used a M584 command to tell RRF that the X and Y motors uses drivers 5 and 6 instead of 0 and 1.
          • undefined
            wydowaw
            @DC42, you are so right !
            I didn't uncomment my new M584 comment I would like to use with the external drivers.
            M584 X5 Y6 Z7:8 E3:4 ;!!! SET mapping to external !!!!
            "working" HBS57 settings :
            NO ENABLE wires connected!
            (no smaller values tested)
            R1 setting generates Red LED error on HSB57 driver.
            #problem solved# Thanks.
            1 out of 5
