    Homing Extra Axis on XYZ+C printer - S1 Issue
    • Algadz
      Algadz last edited by
      Hi everyone,
      First of all, thanks to the Duet team for this wonderfull board full of possibilities 🙂
      I'm working on a 4 Axis particular 3d printer ( XYZCE) with a 0.8.5 DUET ( firmware 1.18.1) and I would like to home the XYZ and C axis.
      I'm doing some test with Pronterface and so far I have :
      Remapped my axis with the following command :
      M584 X0 Y1 Z2 U3 E4
      Set up the endstop with :
      M574 X1 Y1 Z1 U1 E0 S0
      I have checked that my endstop are working fine with the M119 and the board detect all the endstop on and off correctly and I can see them being activated on the board LEDS.
      Everything works fine on the XYZ when I simulate this type of homing macro :
      G91
      G1 X-100 S1
      G92 X0
      G90
      G1 X5
      However when I am doing this same homing routine on my U axis ( which is my C rotary axis ).
      I am able to make a move and to stop when the endstop is activated with G1 U100 S1
      But after this command I am unable to re-use any G1 command without adding S1 or S2 at the end (with the endstop activated or deactivated)
      I mean :
      If I try G1 U10 nothing moves ( either in absolute or in relative mode)
      If I try G1 U10 S1 the axes moves as expected.
      If I restart the board, I am able to use G1 U10 without S1 at the end. This problem appears right after using S1 on the U axis for the first time.
      Also I don't have this Issue on the XYZ axis.
      Did I remapped correctly my axis ? Did I miss Something ?
      Thank you for your help 🙂
      And again, thank you for your work.
        You need to declare the positive and negative limits of the U axis in your M208 S0 and M208 S1 commands respectively. The negative limit will also be the assumed position of the U axis after that G1 U100 S1 command because you have declared the limit switch to be at the low end of the U axis.
        • Algadz
          Oh right,
          the U axis (wich was initially E0), had upper and lower software limit of 0 (checked with "M208" command).
          That was probably causing the trouble.
          Ok I didn't know that the "G1 U100 S1" command (once the endstop is activated) is acting just like the G92 command. Good to know !
          Thank you for your answer 🙂
