    dual z drivers
    • Joelundefined
      Joel
      I set my Duet Wifi up to run dual Z drivers. Everything works OK except that when I do the bed leveling for the lead screws, my results diverge instead of converge. Can I fix this in a config or do I need to get to the Duet ( requires some disassembly ) and swap the Z and E1 cables around?
      Thanks
      Joel
      • Joelundefined
        Joel
        OK, I think I got it, was not hard to figure out. Seems M584 is order driven. I just changed Z2:4 to Z4:2 and it seem to be working.
        Joel
