    Duet Resetting
    178
    • kazolar
      kazolar last edited by kazolar
      Something changed, I had some physical crash, and I'm trying to figure out what wiring got disrupted.
      I am getting a reset
      Last reset 00:04:53 ago, cause: software
      Last software reset at 2019-12-01 22:51, reason: Stuck in spin loop, spinning module GCodes, available RAM 7708 bytes (slot 2)
      Software reset code 0x4043 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000322c Task 0x454c4449
      Stack: 00449d75 0044a0d2 61000000 a5a5a5a5 00449d75 a5a5a5a5 a5a5a5a5 20003250 200030f8 200048d4 0000b483 200062f4 20001778 20003250 200062ec 00000004 200030d0 2000178c 20003250 200030c8 00000001 200032a8 4e49414d
      Got another one.
      Getting very confusing.
      Last software reset time unknown, reason: Assertion failed, spinning module Platform, available RAM 31760 bytes (slot 2)
      Software reset code 0x4090 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f819 BFAR 0xe000ed38 SP 0x2001ff8c Task 0x454c4449
      Stack: 000002f3 00462da8 0044a089 20002be0 0044afe5 00000011 00020000 20005564 00000001 10000000 0043811f 2000628c 00000000 20006228 004462b3 00000000 20006290 2000628c 20006300 20006228 fffffffd 00000000 00f00000
      Any suggestions would be helpful
      EDIT:
      A wire got stuck in the fan.
      Things were overheating -- my best guess.
      No temp errors though.
      Cleared up resets gone
        @kazolar, which Duet, and which firmware version?
        • kazolar
          @dc42 duet 2 2.03RC2. I've never had this happen, I sorta expected a temp error -- as soon as all steppers (duet and duex5) were active about 30 seconds later it would reset -- everything is in a case, but I've been tweaking a few peripheral wires, and one nylon sleeved wire got into the fan for the duet/duex5, so it had no airflow.
          • Veti
            Veti last edited by
            @kazolar said in Duet Resetting:
            0x4090
            do you have a usb cable connected?
              dc42 administrators @kazolar last edited by dc42
              Can you reproduce this issue with firmware 2.04? Another users has also reported a reset when I would have expected an over-temperature warning from one of the drivers.
              • kazolar
                @dc42 I'll update to 2.04 later this week (I have some customizations I've applied to the firmware) -- so I need to move my diffs over. I commented out behavior to comeback to Z after toolchange, a few other tweaks. I'm not sure I would purposely disconnect the fan, but I'll try it. @Veti no, I don't use a usb cable.
                  Please use 2.05RC2 if I have released it by then.
                  • kazolar
                    @dc42 had a reset with most recent 2.05
                    Happened during homing of the gantry axes. Seems this started happening when I started using
                    M42 P7 S255 and G4 as part of the homing routine
                    Here is my home gantry -- I need to use the G4 commands to make sure the homing switches which M42 command toggle are enabled correctly.
                    M42 P7 S255
                    G4 S1
                    G91
                    G1 V700 W700 A-700 Y-700 U700 X-700 F2500 S1
                    G1 Y3 U-3 X3 V-3 W-3 A3 F300 S2
                    G1 Y-20 U20 X-20 V20 W20 A-20 F50 S1
                    M579 U1
                    G90
                    G4 S3
                    M42 P7 S0
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later + DueX5
                    Board ID: 08DGM-9T6BU-FG3S0-7JTD4-3S06K-1A4ZD
                    Used output buffers: 3 of 24 (10 max)
                    Static ram: 25708
                    Dynamic ram: 96296 of which 0 recycled
                    Exception stack ram used: 320
                    Never used ram: 8748
                    Tasks: NETWORK(ready,748) HEAT(blocked,1236) DUEX(suspended,168) MAIN(running,3756) IDLE(ready,156)
                    Owned mutexes:
                    Last reset 00:00:27 ago, cause: software
                    Last software reset at 2019-12-22 23:37, reason: Stuck in spin loop, spinning module GCodes, available RAM 8372 bytes (slot 3)
                    Software reset code 0x4043 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000323c Task 0x454c4449
                    Stack: 00445ac9 00444abc 61000000 a5a5a5a5 00445ac9 a5a5a5a5 a5a5a5a5 20003264 20003104 00000002 200048ec 02c344a8 20001780 20004cf4 20003264 20004cec 00000004 20001794 200030dc 20003264 200030d4 00000001 200032bc
                    Error status: 0
                    Free file entries: 10
                    MCU temperature: min 23.3, current 23.9, max 24.0
                    Supply voltage: min 24.7, current 24.7, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 5: standstill, SG min/max not available
                    Driver 6: standstill, SG min/max not available
                    Driver 7: standstill, SG min/max not available
                    Driver 8: standstill, SG min/max not available
                    Driver 9: standstill, SG min/max not available
                    Date/time: 2019-12-22 23:38:17
                    Cache data hit count 52619560
                    Slowest loop: 8.09ms; fastest: 0.07ms
                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                    === DDARing ===
                    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is idle in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 6.76ms; fastest: 0.02ms
                    HTTP sessions: 1 of 8
                    Interface state 5, link 100Mbps full duplex
