    Need some advice on my config files for bed levelling
    • pipersw
      pipersw last edited by pipersw
      I do bed levelling with two screw.
      Everything is ok, but could you check my file if I do the job correctly ?
      I have a BLTOUCH, on coreXY with dual Z motors.
      config.g
      G90                                      ; Send absolute coordinates...
      M83                                      ; ...but relative extruder moves
      M669 K1                                  ; switch to CoreXY mode
      M550 P"Imprimante"                        ; Set machine name
      M552 S1                                  ; Enable network
      M586 P0 S1                               ; Enable HTTP
      M586 P1 S0                               ; Disable FTP
      M586 P2 S0                               ; Disable Telnet
      M569 P0 S0 F8                            ; Drive 0 goes forwards (X)
      M569 P1 S0 F8                            ; Drive 1 goes forwards (Y)
      M569 P2 S0 F8                            ; Drive 2 goes forwards (Z)
      M569 P3 S0 F4                            ; Drive 3 goes forwards (E0)
      M569 P4 S0 F8                            ; Drive 4 goes forwards (E1/Z2)
      M584 X0 Y1 Z2:4 E3                       ; Set drive mapping, two Z motors connected to driver outputs Z and E1
      M671 X-25:325 Y150:150 S2.0 F1.2		 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M350 X16 Y16 Z16 E16 I1                  ; Configure microstepping with interpolation
      M92 X80 Y80 Z400 E830                    ; Set steps per mm with 1/16 and BMG extruder with 0.9° stepper
      M566 X600 Y600 Z100 E120                 ; jerk, Set maximum instantaneous speed changes (mm/min)
      M203 X15000 Y15000 Z400 E2100            ; Set maximum speeds (mm/min)
      M201 X5000 Y5000 Z1000 E360             ; Set accelerations (mm/s^2)
      M204 P5000 T4000                         ; Set Max acceleration for P=printing moves and T=travel move
      M906 X1400 Y1400 Z1400 E1100 I30          ; Set motor currents (mA) and motor idle factor
      M84 S30                                  ; Set idle timeout
      M208 X0:300 Y-3:300 Z0:205               ; Set axis minima maxima
      ; X Y Endstops
      M574 X1 Y1 S1                            ; Set active high and disabled endstops
      M574 Z1 S2                               ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                      ; Disable heater 3 on PWM channel for BLTouch
      M558 P9 F120 H2.5 R0.5 T6000 A10 S0.005 B1  ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X0 Y80 Z1.10                     ; Set Z probe trigger value, offset and trigger height
      M557 X10:290 Y80:290 P5			 ; Set Z probe point or define probing grid
      ; Thermal Sensors
      M305 P0 T100000 B3950 R4700                  ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R4700     ; Set thermistor + ADC parameters for heater 1
      M305 P101 S"Duet_TMC"                        ; temperature warning and overheat flags on the TMC2660 on Duet
      M305 P103 S"Left_Stepper" X2 T100000 B3950   ; Set thermistor + ADC parameters for left stepper
      ; Calibrate MCU Temperature
      M912 P0 S6.0                                 ; calibrate CPU temperature
      ; Max temp Protection
      M143 H0 S140                                 ; Set temperature limit for heater 0 bed to 140C
      M143 H1 S285                                 ; Set temperature limit for heater 1 hotend to 285C
      ; PID settings
      M307 H0 A249.5 C287.5 D5.7 S1.00 V24.0 B0  ; Disable bang-bang mode for the bed heater and set PWM limit
      M307 H1 A878.0 C303.6 D6.1 S1.00 V24.0 B0  ; Disable bang-bang mode for the nozzle heater and set PWM limit
      M106 P0 S0 I0 F100 H-1 C"Tool_Fan"                ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 C"Extruder_Fan"           ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 H100:101:102 F500 L0.0 X0.05 B0.5 T50:70 C"Duet_Fan"        ; set fan 2 value, turn on at 50% if the CPU temperature reaches 55C, and increase to full speed gradually as the temperature rises to 70C
      M563 P0 D0 H1                            ; Define tool 0
      G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
      G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
      ; Pressure Advance
      M572 D0 S0.2                             ; enable pressure advance
      ; Led strip
      M307 H2 A-1 C-1 D-1                                       ; Disable heater 2 on PWM channel for LED strip
      ; firmware retractation (activate in slicer)
      M207 S1.2 F2100 Z0.075                   ; retract 1.2mm 35mm/s
      T0                                       ; Select first tool
      M564 H0     ; allow movement of axes that have not been homed
      M501                                    ; Read stored parameters from EEPROM
      bed.g
      ; bed.g
      M561                          ; clear any bed transform
      G28 			; Home
      G30 P0 X0 Y150 Z-99999       ; probe near left leadscrew
      G30 P1 X300 Y150 Z-99999 S2   ; probe near right leadscrew and calibrate the 2 motors to achieve self leveling
      ;G28 Z				; Home
      homeall.g
      ; homeall.g
      ; called to home all axes
      M80                     ; power on 24V power supply
      G4 S1                   ; wait 1s
      M42 P2 S255             ; power on led
      M280 P3 S160 I1         ; Alarm Release and Push-Pin UP
      G1 Z5 F1000 S2          ; lift Z relative to current position
      G1 S1 X-335 Y-315 F4000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 S1 X-335             ; home X axis
      G1 S1 Y-315             ; home Y axis
      G1 X5 Y5 F4000          ; go back a few mm
      G1 S1 X-335 F400        ; move slowly to X axis endstop once more (second pass)
      G1 S1 Y-315             ; then move slowly to Y axis endstop
      G1 X150 Y70 F4000       ; go to center bed probe point and home Z
      M558 A1 F300		; Set single probing at faster feed rate
      G30 			; Do a single probe to home Z axis
      M558 A10 F100		; Set detailed probing at slower feed rate
      G30
      I have to do a G28 Z or a G30 Z0 at the end of bed.g ?
        Phaedrux Moderator @pipersw last edited by
        @pipersw said in Need some advice on my config files for bed levelling:
        I would think so, since any tilt correction would have moved the Z0 position at the center of the bed.
