PanelDue 5 v3 gets unresponsive while not printing
  • I have an issue with FW 2.04. as soon as i enable cold Extrusion and start the Extruder Motor, my panelDue 5 gets unresponsive. Reproducible.
  • Moderator
    What firmware version are you running on the PanelDue?
    How is the PanelDue connected? Ribbon cable or 4 wire cable?
    Is the extruder wiring running alongside the PanelDue wiring?
    How are you starting the extruder motor?
  • What firmware version are you running on the PanelDue?
    Latest 1.23.1, i think. Same issue with previous Release.
    How is the PanelDue connected? 4 wire cable, shielded, 60cm? Tried replacing the cable already.
    Yes, but i have tried to separate them before Posting here.
    DWC2 Page general
