CNC JOB error = G0/G1 Machine out of limits
Hello all,
I have a friend who has purchased a Workbee like CNC, but the shop selling it has renamed the CNC. I try to cut some files o, but I get the following error
G0/G1 Machine out of limits !!!!
The CAM is produced by Aspire, the job size is set 100x100, origin is set in the middle, and the part is almost 20x20 , METRIC.
Machine has operating size 512x490 if you check config.g!The procedure I follow is
- Home all
- Move machine in exactly the center or near center ( since Aspire origin is at Center ), position Z
- Push SET JOB COORDINATES, machine XYZ goes to 0/0/0
- Start
- Error pops up
I am posting it here, as the people selling the machine are total noobs and have no clue. If I have to refer to workbee, please let me know.
Thank you for your time
These are my config.g, homeall.g and SetWorkCoordinates.g files
; Configure Connection - ENABLE ONLY ONE OF THE BELOW THREE
;M552 S1 ; Enable Wifi Network
;M552 S2 ; Enable Access Point Mode
M552 S1 P192.168.1.150 ; Enable Ethernet - Change IP Address to suit; - - - - - - - - - - - - - - - - - - - -
; DO NOT CHANGE ANY OF SETTINGS BELOW
; TO MAKE A CHANGE, COPY THE LINE OF CODE, PASTE IT INTO customconfig.g. THE CHANGE CAN THEN BE MADE IN customconfig.g
; ANY ADDITIONAL SETTINGS SHOULD BE PUT IN customconfig.g; General preferences
M453 ; Put the machine into CNC Modes
M550 P3dedge Termite CNC Machine ; Set machine name
G90 ; Set absolute coordinates; Network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Configure Drives
M584 X0 Y1:3 Z2 ; Apply drive mapping to axes; Configure Axes
M92 X53.355 Y53.340 Z400 ; Set steps per mm
M350 X16 Y16 Z16 I1 ; Configure microstepping
M566 X500 Y500 Z500 ; Set maximum instantaneous speed changes (mm/min)
M203 X4000 Y4000 Z2500 ; Set maximum speeds (mm/min)
M201 X125 Y125 Z120 ; Set accelerations (mm/s^2)
M906 X2400 Y2400 Z2400 I100 ; Set motor currents (mA); Configure Axis Limits
M208 X512 Y490 Z94 S0 ; Set axis maxima; Configure Endstops
M574 X2 Y2 Z2 S0 ; Set active low endstops; Other Settings
M140 H-1 ; Disable heated bed
M564 S1 H1 ; Disable jog commands when not homed
M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
M501 ; Load Stored Parameters
M98 Pcustomconfig.g ; Execute custom config settings; homeall.g
; called to home all axesG91 ; relative positioning
G21 ; Set units to mm
G1 H1 Z94 F900 ; move quickly to Z axis endstop and stop there (first pass)
G1 Z-3 F2400 ; go back a few mm
G1 H1 Z94 F300 ; move slowly to z axis endstop once more (second pass)
G1 H1 X1500 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
G92 X550 Y520 Z94 ; Set Home Position - change to your machine size.
G1 X-3 Y-3 F2400 ; go back a few mm
G1 H1 X1500 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
G92 X550 Y520 Z94 ; Set Home Position please change to your machine size.
G90 ; absolute positioningG10 P2 L20 X0 Y0 Z0
G55
M500
Anyone???
I never had CNC to work with, but sounds like machine needs to go to negative coordinates, but axis minima limits are 0, so it cant.
Is there anything in customconfig.g or config-override.g?
@CozyP said in CNC JOB error = G0/G1 Machine out of limits:
Is that the exact error message? That message doesn't come from the standard build of RepRapFirmware. What response do you get if you send M115?
Check your clearance height etc. Not sure about aspire, but F360 wants to lift the spindle 10mm by default.
