    Manually resuming print after shutting off.
    Duet Web Control
    • PeterAundefined
      PeterA
      Hi all. Thanks in advance. Can someone point me in the right direction. We have constant power outages (load sheading) since I know when its happening I want to know if I pause the print then power off, can I then resume after 2 hours after powering back on. ? I've already found that the power outage aut resume does not save and resume so I was hoping to do it manually?
        Yes you can pause and power off, It should save the required information when you pause. Then follow the normal steps for resuming.
        https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
        • PeterAundefined
          PeterA
          thanks i'll give it a go.
