Anyone had any experience with CS Labs controllers?
Other control boards
  • undefined
    PaulHew
    Long shot, but I need some assistance.
    I have a friend who has a Plasma cutter that is controlled by a CS Labs controller.
    Spoke to swift cut and they basically said, 'The IP Address cannot be changed, it is written in the firmware'
    Being a person who builds networks for a living I find this not true, everything that connects to an Ethernet network must be able to have its address changed!
    Anyway, if anyone knows how to change the IP Address in the controller for a CS-Labs controller, I would appreciate the help!
    Regards,
    Paul.
    RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
    Voron 2.4 disassembled..... Waiting for the RailCore Mini....
    • undefined
      Dougal1957
      have a look at link it may be the wrong controller but Pg 26 says it is assigned by DHCP makes 3 attempts and then defaults to 10.1.1.2 (takes 10 secs apparently.)
      undefined 1 Reply Last reply 8 Dec 2019, 08:59 Reply Quote 0
      • undefined
        PaulHew @Dougal1957
        @Dougal1957 said in Anyone had any experience with CS Labs controllers?:
        Thanks for the info, greatly appreciated. I will give it a try on Monday when I have found out how to tweak the Mach4 software to take a new IP address.
        Again, thank you.
        P.
        1 out of 3
