    SD Card in paneldue don't work anymore after firmware update
    • gate546
      gate546 last edited by
      I have just updated the firmware to the latest version for both duet wifi and also for paneldue, 7 " version. and all is ok, my problem is the paneldue SD card, it does not work anymore.
      First of all, it does not mounted by default at startup, and when I try to mount it, selecting the card from the interface, it remain permanently in "mounting".
      Before this firmware update, all worked well.
      Any suggestion will be appreciated.
      Dommy
        Are you able to view the files on the PanelDue SD card from the web interface?
        • abbott_m
          abbott_m last edited by
          I've got kind of the same issue, the SD card in PanelDue doesn't mount on startup and when I do mount it via the web interface, it gets stuck in "mounting". I can get around it by clicking refresh in my browser but I can't find any combination of buttons to view the flash card until I fresh the page. Once done it actually works fine but considering that this card is intended to be removed and inserted fairly often (or at least that's what I plan on using it for as uploading a big gcode file via the web interface is just a tad slow), it's a fair bit of hastle.
          Mike
            I'll re-test it in firmware 1.18.1.
