    Warning: motor phase B may be disconnected reported by driver0
    877
    • educaundefined
      educa
      I keep getting this error/warning
      Warning: motor phase B may be disconnected reported by driver(s) 0
      I have atached a nema17 stepper motor and configured it to have
      M92 X3200.00 Y200.00 Z200.00 E420.00      ; set steps per mm
      M350 X2 Y16 Z16 E16 I0                 ; configure microstepping with interpolation
      M566 X50.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X20.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
      Only X motor is connected. The motor is rated for max 1.5A and I tested with all kind of settings between 1 and 1.5
      This motor is driving a leadscrew with 1mm pitch
      So I define it as 3200 steps per mm (based on the default 16x microstepping on duet) and then reconfigure for x2 halfstepping without interpolation (It does the same if I choose x16 I1 however
      As soon as I let my motor reach 900rpm . (resulting in 15mm/s speed on my leadscrew) I start getting these warnings.
      I can however go a lot higher than 900rpm on the motor and it doesn't stall, but what are these warnings and what should I do with them ?
      Are they any indication of step loss? Or is this some kind of bug ?
      Kind regards,
      Bart
      If you do it, do it good.
      • A Former User?
        A Former User
        is the inductance for the motor known? and what is the supply voltage and which board do you have?
        ofcourse also; you're sure the wiring is good and strain relieved at the connectors?
        • educaundefined
          educa
          Inductance is 4.8mH± 20%
          Supplyvoltage is 24vDC
          Wiring is factory wiring and I tried 4 identical motors which makes me think they won't be all faulty
          Any idea ?
          • A Former User?
            A Former User
            Not my strong suit, just wanted to let the wizards have the relevant information. Maybe try the other driver outputs while the clever people spot the thread (power off before moving the motor connector to reduce risk of toasting drivers)
            • Vetiundefined
              Veti
              please plug in your motor values in the emf calculator
              https://www.reprapfirmware.org/
              with an inductance of 4.8 m.H you are pretty much at the max speed for that motor with 3200 steps/mm
              • educaundefined
                educa
                I tried that EMF calculator and indeed I see that when I go past 15mm/s (which is 3200steps per mm) then I and get red numbers
                It also looks like microstepping has nothing to do with it and also that running the motor at 1A lets me achieve higher speeds than running is at 0.5A (under the condition that the motor can produce enough torque of course)
                So now what ? Any suggestions for quality motors which have lower inductance and could give me higher speeds ?
                  dc42 administrators @educa
                  @educa said in Warning: motor phase B may be disconnected reported by driver0:
                  What is the model number of your existing motor; or failing that, its size (including length)? is it 1.8deg or 0.9deg?
                  3200 steps/mm (@ x16 microstepping) is very high for the X axis of a 3D printer. Maybe OK for a CNC machine where greater force is needed and lower speeds are acceptable. Perhaps you should change to a leadscrew with a lead higher than 1mm?
                  • educaundefined
                    educa
                    The current motor is a kysan 1124090 with 4,8mH inductance and 2,8 ohm resistance
                    I can reach around 13mms on my leadscrew with 24vDC and I can even achieve this while powering the motor with only 0.2A while the motor is rated at max 1.5A
                    So the motor is too powerfull for what needed.
                    I tried the EMF calculator (didn't even know this existed) and found out that lower phase inductance can lead to higher speeds.
                    I cannot us other leadscrews because I bought second hand THK KR20 rails which are ultra high precision screws at quite high price 😉
                    So I have to stick with them and I have to find motors with lower inductance if I want higher topspeeds. I'd like to be able to reach 20mm/s if possible because the printer I'll make for this won't go faster than that.
                    Anyway, The motor I'll need probably can we nema 17, but also nema 14 or even 11 since I am perfectly able to run it at 24V 0.2A currently, so there is margin.
                    Any idea where I could find motors specificly suited for higher speeds and having lower inductance ? I have 1 goldenmotor nema11 here (model 28HD1411-02) and that motor should have 4,8ohm resistance and 2,8mH inductance, so this one should go faster.
                    Any tip/shints are welcome
                    • Vetiundefined
                      Veti
                      this
                      https://www.portescap.com/products/disc-magnet-motors/p430-disc-magnet-high-speed-step-motor
                      is mentioned here
                      https://forum.duet3d.com/topic/9834/pressure-advance-killing-extruder-motor/25
                        How about these https://www.omc-stepperonline.com/nema-17-stepper-motor/3pcs-of-nema-17-bipolar-45ncm-64oz-in-2a-42x42x40mm-4-wires-w-1m-cable-and-connector.html. More torque than you need, but only 2.8mH inductance and 1.1 ohm resistance.
                        Most Nema 14 motors have low rated current, which unfortunately also means quite high inductance.
                        • Vetiundefined
                          Veti
                          https://www.exp-tech.de/en/motors/stepper-motors/9132/stepper-motor-nema-17-bipolar-400-steps-2.4-v-dc-0.8-a-17hm5424
                          1.8mh
                            dc42 administrators @Veti
                            @Veti said in Warning: motor phase B may be disconnected reported by driver0:
                            1.8mh
                            That's a 0.9deg motor, so using it would be a very bad idea in this instance. Is there a 1.8deg version with similar characteristics?
                            • Vetiundefined
                              Veti
                              yes
                              https://www.exp-tech.de/motoren/schrittmotoren/9127/schrittmotor-nema-17-bipolar-200-schritte-3-1-v-dc-2-5-a-17hs5425
                                yes
                                That one looks good! @educa, try plugging the values for that motor into the calculator, with the actual current set to 1.5A.
                                • educaundefined
                                  educa
                                  If I plug this one in the calculator (and I enter 2500mA rated and 1500mA given current @ 24vDC, then this motor should theoretically give me 28mm/s before things go red
                                  • educaundefined
                                    educa
                                    I wonder what the back EMF due to rotation is based on. For this last motor that seems so be the limiting factor and not the inductance. It seems like it is related to the Rated holding torque so I guess thats as good as it will get for that motor (if 28 mm/s is the calculated limit, then maybe 25mm/s would be a safe limit and that is a very acceptable speed for what I want to build
                                    • educaundefined
                                      educa
                                      I think I found one who will even go faster. he has a little higher inductance, but half the holding torque.
                                      I can move my axis perfectly fine with only 0.2A on the current motors which are rated at 1.5 , so I require very little force.
                                      Chances are big that this motor will have enough juice to move the axis and will also be able to go faster in the end because if reasonably low inductance EMF, but due to the lower holding torque also more margin in the EMF due to rotation of the motor
                                      ne.com/hybrid-stepper-motor/dual-shaft-nema-17-bipolar-1-8deg-22ncm-31oz-in-1-33a-2-8v-42x33mm-4-wires.html
                                        I use the single shaft version of that motor in one of my printers. It will have more than enough torque for your printer. Plan on 0.8A current.
