    Is my Duet ethernet sd card empty?
    Firmware installation
    • patterson6
      patterson6 last edited by
      After having troubles with the duet Wifi i went the Ethernet route. I got my card to read through usb saying Duet WiFi or Ethernet 3D printer control electronics (COM3). I can connect using Repetier which says
      17:47:52.180 : OpenGL renderer:GeForce GTX 980/PCIe/SSE2
      17:47:52.180 : Using fast VBOs for rendering is possible
      17:48:08.307 : No start signal detected - forcing start
      17:48:08.338 : N1 M11034
      17:48:08.338 : N2 M115
      36
      17:48:08.338 : N3 M10536
      17:48:08.338 : N4 M114
      35
      17:48:08.338 : N5 M111 S698
      17:48:08.354 : N6 T0
      60
      17:48:08.354 : N7 M8028
      17:48:08.370 : N8 M105
      47
      17:48:08.385 : RepRapFirmware for Duet Ethernet Version 1.18.1 dated 2017-04-09
      17:48:08.385 : Executing default.g (no configuration file found)…Error, not found
      17:48:08.385 : Network disabled.
      17:48:08.385 : RepRapFirmware for Duet Ethernet is up and running.
      17:48:08.385 : ok
      17:48:08.385 : FIRMWARE_NAME: RepRapFirmware for Duet Ethernet FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet Ethernet 1.0 FIRMWARE_DATE: 2017-04-09
      However when i put the sd card in my computer to put my IP address in sys/config.g its not thier. The sd card is blank. Says (G:) 7.20gb free of 7.20GB. I click on it and its empty. I can add a file to it and everything if i want. Am i missing something can this sd card really be empty yet work in Repetier?
      I found the sd card folder structure here https://duet3d.com/wiki/SD_card_folder_structure
      If i need to add the files where do i get them?
      • patterson6
        ok i found out i can just write the ip in repetier. https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer
        still having trouble after this step. I wish i had more detailed instructions than. https://duet3d.com/wiki/Getting_connected_to_the_Duet_Ethernet_or_Duet_0.8.5
        • patterson6
          Im getting close
          19:28:58.454 : Network is enabled, configured IP address: 0.0.0.0, actual IP address: 192.168.1.123
          when i type the 192.168.1.123/ in the browser it stays blank and i get this on repetier.
          19:31:40.860 : serial: N70 M10516
          19:31:40.860 : ok T:B:-273.1
          19:31:41.656 : Incoming transaction: Type receiving at local port 80 (remote port 53778)
          19:31:41.656 : HTTP req, command words { GET / HTTP/1.1 }, parameters { }
          19:31:41.656 : Can't open 0:/www/reprap.htm.gz to read, error code 12
          19:31:41.656 : Can't open 0:/www/reprap.htm to read, error code 12
          19:31:41.656 : Can't open 0:/www/html404.htm to read, error code 12
          19:31:41.656 : Webserver: rejecting message with: not found
          19:31:41.656 : ConnectionLost called for local port 80 (remote port 53778)
          19:31:43.922 : N71 M105
          17
          19:31:43.922 : serial: N71 M105*17
          i did change M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address like on https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer. maybe thats messing me up idk
          • patterson6
            Ensure that the /www folder on the SD card is populated with the required web files. So i guess thats whats stopping my page to load because its just blank no error or nothing.
            • patterson6
              wow so that was it.
              If you want to do this start with installing duetwebcontrol on the sd card you will find here.
              https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-Ethernet/Stable
              make sure it looks like this on your card
              download the device driver zip to your PC and make sure your device manager reads your duet with the sd card installed
              https://github.com/dc42/RepRapFirmware/blob/dev/Driver/DuetDriverFiles.zip
              load repetier and connect
              send M552 command and you should see this
              Network is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
              install your ethernet and send M552 S1 to turn it on
              19:57:33.309 : Network is enabled, configured IP address: 0.0.0.0, actual IP address: 192.168.1.123
              you should see something like this.
              load a browser and enter the IP your duet gave you in the browser. 192.168.1.123/
                I'm sorry that you appear to have been send a board with an empty SD card.
                The production process is being changed so that in future, boards will be tested using the same SD card that they will ship with, instead of testing them with one SD card and shipping them with a different one as now.
