    Macro feedback to users
    • Neotko
      Neotko last edited by
      Hi!
      I'm preparing a setup for um2 users, and I would like to make a macro system to emulate the manual caubration of the z, since um2 doesn't has a probe and the z is at the bottom of the machine.
      The basic idea to make this without changing the webserver, is to make a range of macros for each step so the user can use them and simulate a manual calibration, but to make things easier I will like to send a feedback to the users.
      So, is there a way to send a Text to the webserver when a macr has end or at the start with a pause? I think I did read all the gcodes available but didn't found one to send txt to the webserver/paneldue. It would make things much easier, but ofc I can do this with just a Beep feedback or a Led change.
      So, masters of duet3d, is this possible since there are no Pauses when using linked macros?
        See https://duet3d.com/wiki/G-code#M117:_Display_Message and https://duet3d.com/wiki/G-code#M300:_Play_beep_sound. There is currently no pause facility other than M226. I am not sure whether that one will work in a macro, and if it does it will run pause.g so it is probably not what you want.
        • Neotko
          Ahh ofc M117. That should work! With a series txt and some nice order it might just work. Thanks! Will start macro in it.
