    names not showing properly after upgrade to webcontrol 2
    Duet Web Control
    • r123undefined
      r123
      Have following in config.g
      ; Thermistors
      M305 P0 T100000 B3950 R4700 H0 L0 S"bed"		; Put your own H and/or L values here to set bed thermistor ADC correction
      M305 P1 T100000 B4725 R4700 H0 L0 C7.06e-8 S"nozzle"	; Put your own H and/or L values to set first nozzle thermistor ADC correction
      M305 P2 T100000 B4725 R4700 H0 L0 C7.06e-8 S"chamber" 	; chamber temperature
      In webcontrol 1 had these showed up as "bed', "nozzle' and "chamber". Now with webcontrol 2 only "bed" is correctly named? What's going on?
      • deckingmanundefined
        deckingman @r123
        @r123 It looks like you are using the tools tab so you'll only see tool names and the bed there. Try clicking on the "Extra" tab and you should see the nozzle and chamber temperatures there I think.
        Edit. If you want the tool name to be something different, use the "S" parameter in M563.
        • r123undefined
          r123
          @deckingman said in names not showing properly after upgrade to webcontrol 2:
          M563
          Thanks. Looking much better now.
