    Multi-axis homed Z error
    Firmware installation
    219
    • adri84dj
      adri84dj last edited by adri84dj
      Good afternoon,
      I am building a coreXY with three Z axes, and with independent limit switches in Z max.
      The three Z motors and limit switches are connected in Duex5.
      The problem comes when doing the homing of Z, at the end of the code, I put the three axes back together in Z, but at the end of the homing Z, DWC gives an error message that the homing Z failed.
      It does all the homing Z process, but at the end it gives the homing Z error message, and the "homing Z" button does not turn blue.
      This is my homez.g file configuration
      ; Home 3 Independent Z-Axis Drives
      M400 ; Wait for movement to stop
      G91 ; relative positioning
      M584 X0 Y1 Z2 U3 V4 W5 A6 B7 P8
      G1 W500 A500 B500 F600 S1 ; lower all z motors until each corresponding z-stop reached
      G1 B-4 F300 S2 ; raise Z3 axis slowly (S2 Ignore endstops and ignore axis not homed)
      G1 B10 F300 S1 ; lower Z3 motor slowly until its endstop reached
      G1 A-4 F300 S2 ; raise Z2 axis slowly (S2 Ignore endstops and ignore axis not homed)
      G1 A10 F300 S1 ; lower Z2 motor slowly until its endstop reached
      G1 W-4 F300 S2 ; raise Z1 axis slowly (S2 Ignore endstops and ignore axis not homed)
      G1 W10 F300 S1 ; lower Z1 motor slowly until its endstop reached
      ; This test move before combining axis works
      ;G1 W-50 A-50 B-50 F360 S2 ; raise Z1 axis slowly (S2 Ignore endstops and ignore axis not homed)
      M584 Z5:6:7 P3 ; combine z axis motors
      ;G1 Z-200 F600 S1 ; test raise all axis slowly
      G90 ; absolute positioning
      adri84dj dc42 2 Replies Last reply Reply Quote 0
      • adri84dj
        adri84dj @adri84dj last edited by
        This post is deleted!
        • JustD
          JustD last edited by
          Hi, I don´t know if it helpfull. But here the interesting config part.
          ; Mapping of Driver for X,Y, Z1-3, E1-3
          M584 X0 Y1 Z5:6:7 E3:4:8 ; three Z motors connected to driver outputs 5, 6 and 7 (U,V,W), driver 8 for E2
          M667 S1
          ; BLTouch - Heater 7
          M307 H7 A-1 C-1 D-1 ; Disable heater 7 to free up PWM channel 5 on the Duex board.
          ; BLTouch - FAN2 Ch 22
          ;M106 P2 I-1 ; Disable Fan2 Duet to free up PWM channel 22 on the Duet board.
          ; Define the X and Y coordinates of the leadscrews.
          M671 X8:360:162 Y370:370:5 S3
          M569 P0 S0 ; Drive 0 goes backwards X
          M569 P1 S0 ; Drive 1 goes backwards Y
          M569 P3 S0 ; Drive 3 goes backwards E0 (E1)
          M569 P4 S0 ; Drive 4 goes backwards E1 (E2)
          M569 P5 S0 ; Drive 5 goes backwards Z1/U
          M569 P6 S0 ; Drive 6 goes backwards Z2 V
          M569 P7 S0 ; Drive 7 goes backwards Z3 W
          M569 P8 S0 ; Drive 8 goes backwards E2
          M350 X16 Y16 Z16:16:16 E16:16:16 I1 ; Configure microstepping with interpolation
          M92 X80 Y80 Z800:800:800 E97.24:97.24:97.24 ; Set steps per mm
          M566 X900 Y900 Z20:20:20 E990:990:990 ; Set maximum instantaneous speed changes (mm/min)
          M203 X12000 Y12000 Z800:800:800 E1600:1600:1600 ; Set maximum speeds (mm/min)
          M201 X500 Y500 Z400:400:400 E900:900:900 ; Set accelerations (mm/s^2)
          M906 X950 Y950 Z1200:1200:1200 E990:990:990 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30
          M208 X370 Y370 Z430 S0 ; Set axis maxima
          M574 X1 Y2 S1 ; Set X=low end Y= high end active high endstops
          M574 Z1 S2 ; Define Z1 to use Probe at low End. Home to Min. S2 = Z probe
          ; Depending on wich connection for BL-Touch is used
          M558 P9 H7 F500 T9000 X0 Y0 Z1 ; Set Z probe type 5 to bltouch (P5 as Betrue3D) and the heater (7) height + speeds (+ B1)
          G31 P25 X+25.7 Y+3 Z 1.471 ; <- <- <- Set Z probe trigger value (1-25, not 500), offset and trigger height (3fach-PH noMixing)
          M557 X45:325 Y25:325 S30 ; Define mesh grid
          Own Tronxy X5S modified to 360x360x430, 7 linear-rails (4 Z; 2 Y; 1 X-Axis), 3 independent Z-Axis with 3 Steppers; BL-Touch..
          Duet 2 Wifi 1.04 + DUEX5, 3input-nozzle with 3 extruders, 6mm Glas Plate and 600W silicon-headbed with own powersupply.
          • adri84dj
            When uniting the Z axis in W, A, and B, the homing is correct, but when joining W, A, and B on a single Z axis, it is when I get the homing error message
            • deckingman
              deckingman @adri84dj last edited by
              @adri84dj How have you defined the motors in your config.g? Assuming you use 3 motors and they are on drivers 5,6 and 7 you probably need to use the format M584 Z5:6:7 W5 A6 B7. Actually you only need define two additional axes so M584 Z5:6:7 W6 A7. Then at the start of your home Z you simply use M584 Z5, then you can home Z, W and A independently then map Z back to 5:6:7 at the end of homing.
                dc42 administrators @adri84dj last edited by dc42
                @adri84dj said in Multi-axis homed Z error:
                That's because you have homed axes A, B and W but not Z. I suggest you use one of the following solutions:
                • Create 2 new axes instead of 3, for example, W and A. Then home Z, W and A exactly as you currently home B, A and W.
                • Switch to RRF3 (we are about to release 3.0RC1), then you don't need to create any new axes.
                • Or use just one endstop switch and use the Z probe to do the individual leadscrew adjustment (there is a wiki page about this).
                adri84dj 1 Reply Last reply Reply Quote 0
                • adri84dj
                  adri84dj @dc42 last edited by
                  Since all three motors (W, A, B) are connected in drivers 5, 6, 7 of the duex5, I would like the limit switches to be connected in the duex5 as well.
                  If I make the configuration that you suggest, (Z, W, A), the end of the road associated with Z should be connected to the Z port of Duet 2.
                  Is there any way I can connect the three race finals on duex5, without having to switch to RRF3?
                  Regards.
                  • deckingman
                    @adri84dj You can still have Z connected to driver 5 - see my post above.
                    • adri84dj
                      adri84dj @deckingman last edited by
                      @deckingman said in Multi-axis homed Z error:
                      hello, and this is how I have it now, but the end of the race I have to connect to duet 2 to port Z
