    How much current can we draw on io_x DUET 3
    • steevebeckerundefined
      steevebecker
      How much current can we draw on the 5V pin of a IO_x of a DUET 3 EXP3HC ?
      Can I use this pin to power a RC servo that may draw 0.65A ?
      plant your ideas, water suggestions and questions, collect progress and do great things.
      TLASundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • TLASundefined
        TLAS @steevebecker
        @steevebecker
        Not official here, but might depend on what else you are powering. I thought there was a 3A total limit on the 5V including Raspberry Pi and Dotstar.
        Might check documentation in those areas or the forum posts about powering the Pi from the Duet.
          dc42 administrators @steevebecker
          @steevebecker said in How much current can we draw on io_x DUET 3:
          If you are already powering a RPi from the Duet, then another 0.65A may be a little too much. In standalone mode, not a problem.
          Dougal1957undefined 1 Reply Last reply Reply Quote 0
          • Dougal1957undefined
            Dougal1957 @dc42
            @dc42 said in How much current can we draw on io_x DUET 3:
            Is that the same on an Expansion board David as there won't be a Pi on that?
              The 5V regulator on an expansion board is rated at 1A total. The MCU takes about 0.1A.
              Note, large servos dump power into the +5V rail when they decelerate. The internal 5V rail on the expansion board (and the Duet 3 main board) are protected against over-voltage, but could damage anything else that you connect to the 5V outputs.
