    RRF 3.0RC1 Z Homing Issue (Analogue Mode)
    Beta Firmware
    427
    • tekkydaveundefined
      tekkydave
      I think there might be an issue with z homing using an analogue probe (type P1 in M558).
      I have a piezo probe using the Precision Piezo Universal PCB V2.85 which has both analogue and digital outputs.
      Defined as follows
      ; Analogue Mode
      ;M558 P1 C"^!zprobe.in" R0.5 H3 F360 T9000 A5 S0.03   	; P1 = Analogue mode (V36)
      ;G31 X0 Y0 Z-0.1 P530                      		; X, Y, Z offsets, P530 = trigger threshold 	(V37)
      ; Digital Mode
      M558 P8 C"^!zprobe.in" R0.5 H3 F240 T9000 A5 S0.03   	; P8 = Digital mode (unfiltered)		(V35)
      G31 X0 Y0 Z-0.1 P100                      		; X, Y, Z offsets, P100 = debounce interval 	(V32)
      I have both modes setup for testing and can easily switch between them.
      The analogue mode works fine on 3.0beta12 despite the 1/3 slowdown, which I have mentioned in another post.
      I upgraded to 3.0RC1 this morning and getting lots of "Error: Z probe was not triggered during probing move" errors. It seems to do the first probe which triggers ok, however the 2nd probe always stops about 1mm short and the error is reported. This is the same regardless of using homeall or homez and trying different dive heights, trigger thresholds etc. I have also downgraded back to 3.0beta12 and the fault disappears. It reappears on upgrading to 3.0RC1 again.
      Here are the relevant homing files.
      homeall.g
      ;   X and Y Homing
      G91                    ; relative positioning
      G1 Z5 F360 H2          ; lift Z relative to current position
      G1 H1 X-320 Y320 F4000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-320 F4000      ; home X axis
      G1 H1 Y320 F4000       ; home Y axis
      G1 X5 Y-5 F1800        ; go back a few mm
      G1 H1 X-320 F360       ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y320 F360        ; then move slowly to Y axis endstop
      G90                    ; absolute positioning
      ;   Z Homing
      G1 X150 Y150 F9000      ; go to centre of bed
      G30                     ; home Z by probing the bed
      G1 Z5 F360              ; uncomment this line to lift the nozzle after homing
      homez.g
      G1 Z3 F360 H2       	; lift Z relative to current position
      G1 Z3 F600          	; lift Z relative to current position
      I will post full config.g or any other info required.
      I have reverted to using digital mode for now but I would prefer to use analogue mode as it avoids having to fiddle with the tiny, fragile pots on the PP PCB.
      Cheers
      Dave
      ~ tekkydave ~
      D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
      FreeCAD, PrusaSlicer
        tekkydave
        Not sure if relevant but I have 3 independent z motors with 2 of them on a Duex2.
        Cheers
        Dave
        ~ tekkydave ~
          tekkydave
          My config.g
          config.g.txt
          ~ tekkydave ~
            I've put this on my list to look at.
              Does the digital mode still work in 3.0RC1?
              tekkydaveundefined 1 Reply Last reply Reply Quote 0
                tekkydave @dc42
                @dc42 Yes. No problems with digital mode.
                ~ tekkydave ~
                  I think I have found the reason for the problem, although I don't have a printer using an analog probe at present so I can't test the fix. Please try the Duet2CombinedFirmware.bin file at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                    tekkydave
                    I'll test it asap. Will be tomorrow now.
                    ~ tekkydave ~
                      tekkydave @dc42
                      @dc42 said in RRF 3.0RC1 Z Homing Issue (Analogue Mode):
                      Yes, that has solved the problem. Many thanks and a Merry Christmas 🎅 😃
                      ~ tekkydave ~
