    Z probe is not ok
    • maxxouundefined
      maxxou
      i am beginner in printer 3D
      i have a IR sensor DC42
      About 4 seconds after power is applied, i have the 4 flash
      the Z probe does not work in the duet web control: it don't stop for the Home Z
      Thanks for your help
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sat Apr 22 2017 19:59:56 GMT+0200
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M667 S1 ; Select CoreXY mode
      M208 X300 Y290 Z300 S0 ; Set axis maxima
      M574 Z0 S0 ; Define active low and unused microswitches
      M574 X2 Y2 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:285 S20 ; Define mesh grid
      M569 P0 S1 ; Drive 0 goes backwards
      M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
      M92 X400 Y400 Z6400 E1674 ; Set steps per mm
      M566 X900 Y900 Z15 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z200 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z30 E100 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M140 H-1 ; Disable heated bed
      M563 P0 D0 H1 ; Define tool 0
      M550 Pmaxprinter ; Set machine name
      M552 P192.168.0.109 S1 ; Enable network and set IP address
      M553 P255.255.255.0 ; Set netmask
      M554 P192.168.0.??? ; Set gateway
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      T0 ; Select first tool
      ; homez.g
      ; called to home the Z axis
      ; Lift Z relatively to current position
      G91
      G1 Z5 F6000
      ; Back to absolute positioning
      G90
      ; Go to first bed probe point and home the Z axis
      G1 X150 Y150 F6000
      G30
      ;G91
      ;G1 Z5 F100
      ;G90
      ; homeall.g
      ; called to home all axes
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z5 F6000
      ; Course home X or Y
      G1 X305 Y305 F1800 S1
      ; Course home X
      G1 X305
      ; Course home Y
      G1 Y305
      : Move away from the endstops
      G1 X-5 Y-5 F6000
      ; Fine home X
      G1 X305 F360 S1
      ; Fine home Y
      G1 Y305 S1
      ; Absolute positioning
      G90
      ; Go to first bed probe point and home Z
      G1 X150 Y150 F6000
      G30
      ; Uncomment the following line to lift the nozzle after probing
      ;G1 Z5 F100
        This line is the problem:
        As stated in the fitting instructions, you must always use a P parameter of 500 in the G31 command when using the IR sensor.
        • maxxouundefined
          maxxou
          i must to declare my Z endstop (ir sensor) in the M574 command in config.g ?
          yet i don't have microswitch, it's not clear
          ok thanks DC42
