    Hemera 24V auto tune failing
    • Wannageeringundefined
      Wannageering
      Hi all, been having heater problems with my Hemera on a Duet 2 Ethernet.
      The auto tune starts, heats fine until 200-210 degrees and then kind of stops heating... See attached screen shot.
      Any idea what can be done here? Without PID tuning I'm also getting heater faults all the time.
      • Vetiundefined
        Veti
        these sudden spikes indicate a problem with the thermistor as you cant instantly change the temperature by 20 degrees.
        check the cabling and see if there is some intermittent connection.
          Wannageering
          Okay I will do that, thanks!
