St3di ModelSmart 280 Pro
  • Re: [Fried my printer](Can I 'upgrade' to Duet?)
    Nice printer.I almost finished converting. The quicker way to convert is to rid off old electronics and wiring ,and place with the new stuff.
    Regards fans yes whey are 12 volts Where is two options :add 24v to 12v converter ,from existing main board (Where is 2 on it).
    Or change fans with 24v .Fans are 40mm all over the printer.2 fans are on a head one for cooling extruders and other for cooling plastic. I done a mistake by buying and not counting how many blades are on a fan it just makes more noise.
    QUESTION???HOW TO!!!
    Printer has servo mounted on the right hand side on XY axes.On the servo arm where is mounted switch .When arm is vertical , switch act as probe and Z min .When horizontal it act as X min.
    HOW TO CONFIGURE IN A FILES??
    Let’s scratch heads together : D
