    M569 settings not work with external driver(tmc2208)
    404
    • seraserundefined
      seraser
      Hi.
      I have a ramps board adapted to duet because for only one driver for dual extrusion do not need a expansion board.
      The problem is I cant set values for stealchop in P5 see:
      In config.g
      M569 P5 S1 R0 D3 ; E1 Drive 5 goes forwards
      Console output after reboot
      M569 P5: Drive 5 runs forwards, active low enable, step timing fast
      Parameter Dnnn do not take effect
      Tmc2208 work but with bad condition to much over extrusion and I want set other parameters.
      Firmware 2.04RC3
      Thank you.
      • Danalundefined
        Danal
        If I understand your question correctly...
        This external TMC2208, what wires are connected from the Duet? Power? Step/Dir? Anything else?
        Setting any internal registers in a TMCxxxx driver requires either SPI or serial UART. Duet uses SPI. Is SPI connect from the Duet to the external TMC2208? If not, then those parameters will never work.
        seraserundefined 1 Reply Last reply Reply Quote 0
        • seraserundefined
          seraser @Danal
          @Danal
          Yes, step, dir and enable.
          So thank you, I think I cant connect via spi so no option to work.
          • Danalundefined
            Danal
            No option to change defaults. You might wish to use a TMC that accepts jumpers for configuration, like the 2103, for an external.
            • seraserundefined
              seraser
              Ok, I will order TMC2130, thank you.
                dc42 administrators @seraser
                @seraser said in M569 settings not work with external driver(tmc2208):
                That won't help, if it's a Duet WiFi or Ethernet then the only type of smart driver supported in the standard firmware build is TMC2660.
                seraserundefined Danalundefined 2 Replies Last reply Reply Quote 0
                • seraserundefined
                  seraser @dc42
                  @dc42 Ok, no dual extrusion for me, arggg, because I have double Z in three printers with duetwifi.
                  Thank you.
                  Vetiundefined 1 Reply Last reply Reply Quote 0
                  • Danalundefined
                    Danal @dc42
                    @dc42 said in M569 settings not work with external driver(tmc2208):
                    External. From the Duet, only Step/Dir/Enable via the expansion port. All other options set by jumpers local to the external chip.
                    Obviously, can not use Duet config commands to set options.... other than that, it should work???
                    • Vetiundefined
                      Veti @seraser
                      that is what the duex2 and duex5 is for.
