    Home Z with BLTouch
    • brasseundefined
      brasse
      Hey, im trying to edit the homez.g to allow my Z to safely home. The probe is positioned outside the bed, so when i try to home the probe does not hit anything.
      Ive tried this setup, but it wont move X/Y-axis before running the G30 command.
      G90 ; Make sure we are in absolute mode
      G1 S1 X100 Y100 F1800; move to middle of bed
      G30 ; Do a single probe to home our Z axis
      G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
      Whats is the recommended way to set up the homez.g when having the probe outside the bed when X/Y is homed?
      Best Regards // Lars
      Phaedruxundefined zecchiundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @brasse
        @brasse said in Home Z with BLTouch:
        Take out the S1
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe
        • zecchiundefined
          zecchi @brasse
          @brasse
          This is mine:
          You can also remove 'H0' , is useless.
          M558 Fxxx is used to reduce speed
          If your probe goes outside the bed maybe you have done some mistakes during configuration (like me😊 ).
          To solve I've configured (via RRF tool) the firmware and upload it overwriting the old files.
          (Probably your mistake is in probe's offset , in my case was only a minus before the number !!)
          brasseundefined 1 Reply Last reply Reply Quote 0
          • brasseundefined
            brasse
            Awesome, worked fine. Thanks 🙂
            • brasseundefined
              brasse @zecchi
              @zecchi Thanks for input, will try to generate a new config 🙂
