Duet3 - Python - Preliminary class for interfacing
  • I've created a preliminary module/class to allow Python programs on the Pi attached to a Duet3 to interact with the printer. It does so via the "Duet Control Server" socket (not websocket) connection in the "Duet Software Framework".
    It is available on Github https://github.com/DanalEstes/PythonDSF
    This is an early implementation and it may radically change in the near future. Nonetheless, if you are thinking about Python scripting, give it a try.
    There is also an example script. This script is intended to do tool-to-tool measurement to derive offsets on a "Tool Changing" 3D printer of the E3D tool-changer type. Specifically, it is for my Jubilee. There are some instructions in the README about how all this works. This is a whole topic in and of itself.
    A very minimal example of use might look something like this:
    #!/usr/bin/env python3
    import pythondcs
    dcs = pythondcs.PythonDCS()
    dcs.gCode('G0 Z10       F1000')          # Lower bed to avoid collision with square hole plate.
    dcs.gCode('G0      Y225 F10000')        # Move nozzle to avoid other tools
    r=getPos()
    print("X position ="+r[0])
    There are several other modules, including a "r=getPos()" that returns a Python list containing the current position of the printer, in mm. See the example script.
  • Nice! Is it only working for Duet3, or also for Duet2 running RRF3?
  • @fma said in Duet3 - Python - Preliminary class for interfacing:
    for now only Duet 3 support Raspberry Pi and this class interfaces to a unix socket on the Pi; so this only works for Duet 3 + raspberry pi (i.e. not Duet 3 in stand alone mode)
  • Ok, I though you where connected on a Duet socket...
    Correct, a socket, NOT a websocket.
    The stack for a Duet 3 with a Pi is roughly:
    Browser on PC or Mobile
    <Wifi or Ethernet TCP/IP network - Websocket protocol>
    Duet Software Framework Web Server on Pi
    <Linux internal - Socket protocol>*
    Duet Software Framework Control Server on Pi
    <Ribbon Cable - SPI Protocol>
    Firmware on Duet 3 6HC board
    The * indicates where this python connects; Therefore it must run on the Pi where that socket resides.
    If enough people are interested, I can look into a Websocket version. This could theoretically run on any machine that has TCP/IP network connectivity to the Pi or a stand-alone D3.
  • Just stumbled on this. Many thanks for putting this together @Danal !
    I decided to give it a whirl on my Pi and landed on an IncompatibleVersionException, which closed the connection immediately. Does something need to be updated? I'm running...
    Firmware Version console output
    echo "m115" | sudo /opt/dsf/bin/CodeConsole
    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-19b2
    Apt Package Version
    Package: duetsoftwareframework
    Version: 3.1.1
    and the specific error is:
    {"errorType":"IncompatibleVersionException","errorMessage":"Incompatible protocol version (got 0, need 7 or higher)","success":false}
    Thanks for taking a look!
  • Ah, figured this out. It looks like the request to enter "command" mode must also include the protocol version.
    j=json.dumps({"mode":"command", "version": 8}).encode()
    The server picks up the missing field as 0 and closes the connection immediately.
    It looks like this isn't stated yet in the Duet Software Framework docs, but I got a pro tip from @wilriker on this thread.
    Thanks for the breadcrumbs everyone!
