    Dual PSU question.
    • Dkos
      Dkos last edited by
      Hello people,
      I am currently running my printer with a chinese PSU (300w) that came with my first printer kit. Although it is currently working fine (for almost 2 years now), a bit noisy but fine, i was considering of removing some load from it. I have an ATX PSU laying around from a small factor HP PC i had. It is 250w and my though is to use this ATX psu for my Duet, and the led-type PSU for the heatbed (everything is currently running at 12v).
      My question is: Does it matter which one I use for the main (Duet) PSU and which one for the bed? And if i use the ATX as a main PSU should i still use a load resistor just for it to turn on?
      Thanks in advance!
      • Danal
        Danal last edited by
        Doesn't really matter which is which, as long as the wattage for the bed is within each.
        Yes to the resistor.
        Just curious: Duet 2 or 3?
        • Dkos
          Dkos last edited by
          Thanks for the reply!
          I did the configuration everything works fine, thanks!
          As for the board is a Duet 2 Wifi board.
          Cheers!
