    Cannot connect to Duet
    239
    • MrWhippy
      MrWhippy last edited by
      Hello and sorry for the very noob post, but I am having some issues getting started.
      Firstly some background.
      Hardware - Duet 2 Ethernet v1.04 (XYZ control of wood carving machine)
      Firmware - 2.03 dated 2019-06-13
      I have started working my way through the step by step connection tutorials Getting Connected and am getting stuck when trying to connect to my board through firefox/IE/chrome etc.
      I am able to check firmwear, start and stop the network, change the network IP etc etc through YAT, but regardless of what IP address I choose, my browser will not connect...
      Can anyone help?
      Many thanks,
      Chris.
      • Veti
        Veti last edited by
        @MrWhippy said in Cannot connect to Duet:
        you are going through the wifi setup. normally with the ethernet it should get the ip via dhcp.
        what is the ip you assigned and what is the ip of your computer?
        • MrWhippy
          I am 100% only carrying out the steps labelled "Ethernet only"
          I have assigned various IP addresses (192.168.1.14 - 192.168.2.96 - 0.0.0.0) and then changed the port settings on my PC to fixed IP address which matches the IP address fed back to me by the m552 command.
          When I enable and disable the network connection via YAT, it enables and disables the port on my PC, so things seem to be talking through both the USB and the Ethernet cable, but again no browser connection.
          MrWhippy 1 Reply Last reply Reply Quote 0
          • MrWhippy
            MrWhippy @MrWhippy last edited by
            Although with that said, if there is an easier way to connect then please feel free to share!
            A Former User 1 Reply Last reply Reply Quote 0
            • A Former User
              A Former User last edited by
              By the sound of it you are using a direct ethernet connection between your Duet and computer. (No switch, no router, just cable?)
              You need to set a IP address on your computer as well, and one that is in the same subnet on your duet. f.ex.
              192.168.1.14 for the Duet and 192.168.1.15 for the computer (provided your computer is not connected to any other networks which use the 192.168.1.0/24 address range.
              If that still does not work please run route print in the command line on your computer and post results here.
              • A Former User
                A Former User @MrWhippy last edited by
                Easier is to have a router or other device run a DHCP server to hand out IP addresses to both the computer and the Duet.
                • MrWhippy
                  Excellent, thanks for the feedback.
                  You are correct that it's just a pc, cable and duet, as the hardware is all in my workshop and I don't need an internet connection out there.
                  However, I think I have an old router somewhere so if I can't get it to work directly, then I'll try using that. If I use a router, what should I set as an IP address for the duet (if anything)?
                  Thanks again for the help, this is somewhat outside my comfort zone.
                  • Veti
                    Veti last edited by
                    your ethernet card will need to support Auto MDI-X. and sometimes that does not work correctly.
                    • A Former User
                      It should work just fine if you set up both the PC and the Duet to be on the same network. If you have to resort to adding a router M552 S1 P0.0.0.0should get the Duet to ask the router for an IP address, you'll have to enable DHCP for the computer as well if this was set up for a static IP. The command above should give us the information we need to further assist.
                      • A Former User
                        A Former User @Veti last edited by A Former User
                        @Veti said in Cannot connect to Duet:
                        He does say the M552 does affect the link status, so unless he failed to observe that it is only enabled for a brief moment then that should be okay. route print will also show us reveal the link state so waiting for that.
                        • MrWhippy
                          Sorry for the tardy reply, I work away during the week so am only able to gain access to the workshop at weekends.
                          Thanks for all the help and suggestions, simply connecting both the pc and duet cards to the network has solved the problem and everything is running smoothly.
                          Cheers!
