    Fan settings not working
    • jtroutt19undefined
      jtroutt19
      I am wanting to change fan speed according to layer. I have it set up in cura to do this but it doesnt happen when printing. I end up having to change it manually with the slider. Do I have something setup wrong? In the web portal for the printer it also shows three fans which I only have 2. It shows 'Tool Fan' being a fan along with 'Hotend' and 'Blower'
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Apr 17 2019 17:42:43 GMT-0400 (Eastern Daylight Time)
      G90        ; Send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"Ender3"                                                     ; Set machine name
      M586 P0 S1                                                         ; Enable HTTP
      M586 P1 S0                                                         ; Disable FTP
      M586 P2 S0                                                         ; Disable Telnet
      M569 P0 S0                                                         ; Drive 0 goes backwards
      M569 P1 S0                                                         ; Drive 1 goes backwards
      M569 P2 S1                                                         ; Drive 2 goes forwards
      M569 P3 S0                                                         ; Drive 3 goes backwards
      M350 X16 Y16 Z16 E16 I1                                            ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E106.29                                  ; Set steps per mm
      M566 X600.00 Y600.00 Z24.00 E300.00                                ; Set maximum instantaneous speed changes (mm/min) If bad prints change to 600
      M203 X30000.00 Y30000.00 Z800.00 E1500.00                            ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00                                ; Set accelerations (mm/s^2)
      M906 X500.00 Y500.00 Z500.00 E500.00 I30                           ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300                                                           ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S1                                              ; Set axis minima
      M208 X243 Y231 Z260 S0                                             ; Set axis maxima
      M574 X1 Y1 S1                                                      ; Set active high endstops
      M574 Z1 S2                                                         ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                                                ; Disable heater on PWM channel for BLTouch
      M558 P9 H5.0 F120 T6000                                             ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-40 Y0 Z1.78                                           ; Set Z probe trigger value, offset and trigger height
      M557 X50:185 Y50:185 S65                                           ; Define mesh grid
      M305 P0 T100000 B4138 R4700                                        ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                                       ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700                                        ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280                                                       ; Set temperature limit for heater 1 to 280C
      M106 P2 S1 I0 F10 H-1 C"Blower"                                    ; Set fan 0 value, PWM signal inversion and frequency.
      M106 P1 S.5 I0 F500 H-1 C"Hotend"                                  ; Set fan 1 value, PWM signal inversion and frequency.
      M563 P0 D0 H1                                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                                       ; Set initial tool 0 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S10 R11 P"M911 S10 R11 P""M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;M501                                                               ; Load saved parameters from non-volatile memory
        jtroutt19
        Well I think I know the issue. Cura cannot address fans. Being that my blower is P2 and not the default P0 the gcode command being sent wont work. So I think I need to rename my blower fan to P0 in order to get this to work. Well never mind, Seems pwm is not working on fan_0. A bit upsetting.
        Is there any way to remap fan_2 and make it fan_0?
          dc42 administrators @jtroutt19
          @jtroutt19 said in Fan settings not working:
          There are two ways. You can use RepRapFirmware 3 which allows you to map any fan number to any suitable output pin. Or you can use the F parameter in the M563 commands that you use to create tools, to specify which fan is the default print cooling fan for each tool.
