    Duet2 and TB6600+ V1.0
    • Perttiundefined
      Pertti
      I have an extra TB6600 external driver, which I tried with Rumba. The motor became hot and didn´t function because of the signal connection: +5v CLK DIR EN. +5v should have been GND.
      OK, is there any change to wire it with Duet2 Wifi board ? Hate to throw away things.
      If I need the Duet extension board, does it provide drivers or only signal to drivers?
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
        Th datasheet says it has optically isolated inputs. They almost certainly need a 5V signal. So you would need to use the external driver breakout board between the Duet and that driver to get it to work.
        • Perttiundefined
          Pertti
          Ok thanks. I´ll be back when received the board.
          Pertti
          • Perttiundefined
            Pertti
            Now I received the external driver breakout board (hope it's the right one)
            So how do I wire it?
            Pertti
              droftarts administrators @Pertti
              @Pertti See the following:
              https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
              https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
              https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
              My guess is connections on the TB6600 are:
              Green - EN - enable
              Blue - CLK
              Black - DIR
              Red - GND (according to the comment in your first post)
              So choose a header on the Breakout board, eg Drive 5, and connect
              Green > Enable +
              Blue > Step +
              Black > Dir +
              Red > GND
              Configure in config.g by adding something like:
              M584 U5
              M569 P5 R1 T2.5:2.5:5:0
              Which will create a new U axis to test it with.
              This is my best guess. I accept no liability if it blows up your Duet or driver.
              • Perttiundefined
                Pertti
                Thanks, droftarts.
                I'll try this.
                Pertti
