    Duet maestro heated bed
    • Avrimo2undefined
      Avrimo2
      Hello All! Just ordered a Maestro for a 3d printer that I'm currently building.
      I'm planning to acquire 24V 400W 300x300 silicone heated bed. The current rate should be 16.7A which is less than the allowable 18A on the board.
      Would appreciate your assistance with the following questions:
      1. Should I: a) use the internal MOSFET? b) Add an external one? Or c) ass a good quality SSR (I read that MOSFET is better or DC-DC application.)
      2. If the bed is 400W and the rest is approx. 50W I conclude I need to buy 600W PSU as 450W is at the edge (with only one extruder).. is my conclusion reasonable in your opinion?
        I prefer to optimize the payment so 450 is cheaper thus..
      Thanks allot!
      • Vetiundefined
        Veti
        @Avrimo2 said in Duet maestro heated bed:
        how did you arrive at that?
        1 x 40w heater cartridge + all stepper motors would be more than that.
        for the heated bed you should check the resistance before connecting it. its close to the max 18 A.
        • Avrimo2undefined
          Avrimo2
          @Veti e3d v6 is 30w I believe
          • Vetiundefined
            Veti
            25 or 40
            https://matterhackers.dozuki.com/Wiki/E3D_Heater_Cartridge_Resistance
            • Avrimo2undefined
              Avrimo2
              Damn you're right...
              So 600W? Is it standard?
                If the bed heater really does draw 16.7A then a 450W PSU would be marginal. You could get away with a good quality 450W PSU (e.g. MeanWell) if you turn the voltage down a little, especially if you wait for the bed to reach temperature before you heat the hot end. Otherwise you should use a 600W PSU.
                Avrimo2undefined 1 Reply Last reply Reply Quote 0
                • Avrimo2undefined
                  Avrimo2 @dc42
                  This post is deleted!
