RRF3, Error: "Push(): stack overflow" on Maestro
If a Macro including "M291 S3" is started over the 12864 LCD menu system that can cause an error.
Be aware: Reset the system in case you get the error. Elsewhere you can get in trouble with a non deploying Bltouch in homing moves.
That gave me a nice crash into the bed today....The error only appears if the macro is called over the LCD menu. If called over DWC everything works well...
Full description:
To start the macro you have to push the button several times.
The macro then will start without prompting for confirmation. The Gcode gets stuck when a sub macro is called.
To clarify: The call of the macro is not hard coded in the menu system.
It's selected from the macro folder.
Filament_Change.g -
I will try to reproduce this tomorrow.
Hi David, could you please take a look here again?
