    1x 5V fan and 1x 24v fan
    • maroondsundefined
      maroonds
      Is it possible to set 1x 5V part-cooling fan and 1x 24v hotend cooling fan up with the duet maestro?
        droftarts administrators
        Yes. The 4 fan pins are made up of two banks on the Maestro; the three fan headers closest to the main power input are one bank (ALWAYS ON FAN, PWM FAN 0 and PWM FAN 1), and the other bank is PWM FAN 2. There are three-pin connectors on each end of the row of fan pins, that select the voltage for each bank. So you can set the first bank to VIN (ie 24V), and connect the hot end cooling fan to FAN 0 or 1 (if you want to control it), then set the second bank to 5V, and connect the part cooling fan to FAN 2. See the wiring diagram here:
        • Stephen6309undefined
          Stephen6309
          https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
          What you need to do is similar to what is described here:
          https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
            droftarts administrators @Stephen6309
            @Stephen6309 Duet Maestro is a bit different from Duet 2 Wifi/Ethernet, in that it has an extra fan header that has it's own voltage selector. See my answer above.
            • maroondsundefined
              maroonds
              Thanks! Can I control the fan speed of both banks?
                dc42 administrators @maroonds
                @maroonds said in 1x 5V fan and 1x 24v fan:
                AFAIR, one bank has two controllable fans, the other has one controllable and one always-on fan.
