    Stuck on "Updating Firmware" - Duet 2 Maestro
    Firmware installation
    • MrInkaundefined
      MrInka
      Hey,
      I ordered a Duet 2 Maestro, attached it to the USB, followed the guide to set up the network and web interface. I wanted to update the Firmware coming from 2.01.
      I followed the guide on updating it and downloaded a combined package for v3, which the webinterface didn't seem to recognise. I then tried to just update to 2.05, using the "DuetMaestroFirmware.bin" from the last release before v3. The web interface asked me to start the update, which I confirmed.
      So now, the Cr10s5 display keeps showing "Updating Firmware" since around 1 hour. I can't believe, that this is a normal amount of time for a 400kb firmware file.
      At this point I am unsure. The diag-led is solid red, the web interface is not responding. Did I brick the board?
      It would feel wrong to unplug it at this point.
      What could I do?
      • DIY-O-Sphereundefined
        DIY-O-Sphere
        Do you have the iap4s.bin in the sys folder?
        As far as I know you need this one also for the downgrade
        (UTC+1)
        • A Former User?
          A Former User @MrInka
          @MrInka said in Stuck on "Updating Firmware" - Duet 2 Maestro:
          It should be quite fast, a minute or even less.
          Look up the usb programming if you don't get it working.
            DIY-O-Sphere
            @MrInka
            Have you seen that...
            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
            (UTC+1)
