    Load different temp-mesh compensation profiles?
    • TheeRogerWilcoundefined
      TheeRogerWilco
      Perhaps I need to read more 🙂
      Is there a way to do a mesh compensation of the bed at certain temps and then load them when printing different temps?
      I'm guessing I need to find the file it's saved to and then do a macro with each M/G command?
      • Danalundefined
        Danal
        Yes, it is saved to a file in /sys, something like 'heightmap.csv"
        You can copy to files with various names, and then load with M375 P"/sys/filename.csv"
          TheeRogerWilco
          Thanks very much! 🙂
            You can even use M374 to save the current heightmap.csv as another file.
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M374_Save_height_map
