    Solved RRF 3.0 atx power control on dashboard gone?
    Duet Web Control
    • anycase
      anycase last edited by
      I just updated to RRF 3.0 on a duet wifi, and now I no longer have the ATX on and off buttons on the dashoard of DWC and I don't see anywhere where I can put them back on the dashboard. There used to be a toggle to display it in RRF 2.x can anyone tell me how to get it back?
      SteveYYC 1 Reply Last reply Reply Quote 0
      • SteveYYC
        SteveYYC @anycase last edited by
        @anycase
        If you send an M80 command to turn on the ATX power supply the ATX control will appear on the Dashboard view. You can put the M80 command in your config.g file.
        The on-screen control will remain there after the first M80 command is sent.
        pipersw 1 Reply Last reply Reply Quote 0
        • anycase
          That did the trick, thanks!
          • pipersw
            pipersw @SteveYYC last edited by
            @SteveYYC said in RRF 3.0 atx power control on dashboard gone?:
            @anycase
            or you write M81 in your config.g and it's appear without turn on the psu
            SteveYYC 1 Reply Last reply Reply Quote 1
            • SteveYYC
              SteveYYC @pipersw last edited by
              @pipersw I did not know that M81 would also work. Thanks for that!
