    configuring Dual Z w/ Dual Z endstops....
    1.2k
    • dingo007undefined
      dingo007
      ive read the document, though i dont see alot of information about dual Z endstops
      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      also theres also this so im still a bit confused about the right / wrong way to go about this
      https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18
      2 Z screws connected to Y and E1 .. I used Y because my Y is serial Dual steppers also... so i put them on the Z plug
      right now my config.g looks like
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M569 P4 S0 ; physical drive 4 goes forwards
      M584 X0 Y2 Z1:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I80 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z850 S0 ; set axis maxima
      M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
      • Vetiundefined
        Veti
        for dual endstop you should upgrade to rrf3
        see
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
        dingo007undefined 1 Reply Last reply Reply Quote 0
          Your config.g file indicates that you are using RepRapFirmware 2, so the second link in your post is applicable. However, if you are ready to upgrade to RepRapFirmware 3 then it supports multiple axis endstop switches much more directly.
          • dingo007undefined
            dingo007 @Veti
            @Veti RR3 runs on Duet 2 ? I thought it required a raspberrypi 3 ? or is that just for a Duet 3 ? and how does one convert working configs ??
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • dingo007undefined
              dingo007 @dc42
              @dc42 so... Thanks foir the input, use the second link if i stay on RR2, use the first if i decide to go to RR3.... what scares me is the config changes required to get to 3 from 2 when i almost have 2 completely configured properly. 🙂 and RR config doesnt seem to work for RR3.
              • Vetiundefined
                Veti @dingo007
                @dingo007 said in configuring Dual Z w/ Dual Z endstops....:
                yes
                no, not even on the duet 3.
                see
                https://forum.duet3d.com/topic/13630/reprapfirmware-3-0-is-released
                • Vetiundefined
                  Veti @dingo007
                  why not?
                  • dingo007undefined
                    dingo007 @Veti
                    @Veti i tried it, wouldnt let me download anything.
                    • Vetiundefined
                      Veti @dingo007
                      works for me. did you forget to add the io mapping?
                      • dingo007undefined
                        dingo007 @Veti
                        @Veti must have been cashed in the browser.... ok went through it again i see 3 issues..... doesnt appear to let me map E1 to Z2 ... manual edit i guess, hrmm hows the second Z stop get configured LOL 🙂 kill me now... ok ok putting on the patience hat.... and second BLtouch is blanked out 🙂 ... i generated what i could for V3 lemme start manually editing to match what i had for v2 ......
                        • Vetiundefined
                          Veti
                          you need to assign PWM Control Channel (BLTouch only) in io mapping
                          dual z stop is explained here
                          • dingo007undefined
                            dingo007 @Veti
                            @Veti wow this config is really confusing now.....
                            rr2 config.g
                            rr3 config (makes no sense) (M584 X0 Y2 Z1 E3:4 should be M584 X0 Y2 Z1:4 E3 )
                            M569 P4 S0 ; physical drive 4 goes backwards
                            M584 X0 Y2 Z1 E3:4 ; set drive mapping
                            M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z800.00 E420.00:420.00 ; set steps per mm
                            M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                            M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
                            M574 Y1 S0 P"zstop" ; configure active-low endstop for low end on Y via pin zstop
                            M574 Z1 S0 P"ystop" ; configure active-low endstop for low end on Z via pin ystop
                            dingo007undefined Vetiundefined 2 Replies Last reply Reply Quote 0
                            • dingo007undefined
                              dingo007 @dingo007
                              @dingo007 me thinks i see what its doing. it should be
                              M569 P2 S1 ; physical drive 2 goes backwards
                              M569 P1 S1 ; physical drive 1 goes backwards
                              M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
                              M92 X80.00 Y80.00 Z800.00:800.00 E420.00 ; set steps per mm
                              M566 X900.00 Y900.00 Z12.00:12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z180.00:180 E1200.00 ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z20.00:20.00 E250.00 ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                              • Vetiundefined
                                Veti @dingo007
                                yes change it. thats the manual change that you did.
                                • Vetiundefined
                                  Veti
                                  now add your second stop like this
                                  M574 Z1 S0 P"ystop+e0stop" ; configure active-low endstop for low end on Z via pin ystop
                                  • dingo007undefined
                                    dingo007 @Veti
                                    @Veti
                                    And below where it states, makes completely no sense to my brain, can someone explain ?
                                    You must use the M671 command to define the X and Y coordinates of the leadscrews
                                    where my left and right Z screws are at 225 to the bed which is centered of the 450x450 bed
                                    M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                    M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                                    • dingo007undefined
                                      dingo007 @Veti
                                      @Veti said in configuring Dual Z w/ Dual Z endstops....:
                                      Im using Y and E1 so.....
                                      M574 Z1 S0 P"ystop+e1stop" ; configure active-low endstop for low end on Z via pin ystop
                                      • dingo007undefined
                                        dingo007 @dingo007
                                        @dingo007 i guess its..... ???
                                        M671 X0:250 Y0:250 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                        M208 X0:250 Y0:250 ; X carriage moves from 0 to 250, Y carraige goes from 0 to 250
                                        • Vetiundefined
                                          Veti
                                          what are you trying to do now? dual z endstop or independent leveling?
                                          thats only needed for the second one.
                                          • dingo007undefined
                                            dingo007 @Veti
                                            @Veti the document you sent me https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
